  2. sven-ola
    Hi @rm_, I tried my RV2 with current kernel and disabled bcmdhd. For reference, I have uploaded the image to https://privat-in.de under "Downloads". Prevented bcmdhd.ko from loading. There is no such load. I don't thing that waiting a couple of hours will change that. Also, I have zero IPI4 irqs, thus you may need to locate the interrupt source, e.g. with lspci and lsusb. Maybe you changed something in the kernel cfg, please compare attached cfg to your /proc/config.gz). HTH // Sven-Ola config.gz
  4. @alexc @Nick A With the latest changes from you, incorporated by Nick, the 6.18 kernel. This is the boot log of the serial port: uart_log_20260512.md The blue LED is blinking normally, but there is no display output via the DP port on the dock, and the wired Ethernet isn't working either. I haven't tested the PCIe interface yet as I don't have the adapter module on hand.
  5. Try with this commit:https://github.com/armbian/build/commit/b880d98b07090b0b59bb3096c508e5123b224037 Seems like Micha had to cleanup my mess
  6. Yesterday
  7. @meco works perfectly and passes stress-ng. Thanks!
  8. Hello. I installed armbian trixie on orangepzero 2w. OK. I'd like to install Homeassistant on this machine. I went to armbian-config -> Software -> HomeAutomation -> Home Assistant. Installation went smooth< as far as I see. Then I asked to reboot system to enable AppArmor. I did that. After reboot I tried to connect to the machine via Firefox http://192.168.1.16:8123 Nothing happened. Should I issue some commands or do some actions to continue installation? Thanks you you advance. Alexei
  9. Testing Kernel 7, Buiding new images inside docker on 24.04 ubuntu x86 sudo apt update sudo apt install -y qemu-user-static binfmt-support sudo systemctl restart systemd-binfmt update-binfmts --display qemu-aarch64 docker run --privileged --rm tonistiigi/binfmt --install all docker run --rm --platform linux/arm64 arm64v8/ubuntu uname -m git clone https://github.com/armbian/build.git cd build newgrp docker ./compile.sh docker-shell ./compile.sh BOARD=yy3568 BRANCH=current BUILD_DESKTOP=yes BUILD_MINIMAL=no DESKTOP_ENVIRONMENT=gnome DESKTOP_TIER=mid KERNEL_CONFIGURE=no RELEASE=resolute
  10. This week's work centers on release and CI infrastructure, board and U-Boot updates, and build framework hardening. On the release pipeline, asset manifest JSON is now emitted alongside uploads, third-party armbian-images.json sources are merged into the main download index, and dispatch chains were rewired so that build completion fans out cleanly to download-index regeneration and website sync. Ubuntu resolute (26.04) entered the daily build matrix, with corresponding prepare-host adjustments for its qemu-user packaging and a targeted blacklist for boards failing resolute plus GNOME. The new Armbian SDK images are now surfaced on the website and ship preloaded with the build framework, code-server, and developer tooling. On the platform side, U-Boot v2026.04 lands for Helios4, Rock-5B-Plus, Rock-5T, and NanoPi-M5 (with mainline UFS via a vendor-SPL hybrid), while new bleedingedge branches were introduced for rockchip64 and meson64. Initial support arrived for the Photonicat2 board, new RK3576 SPL and RK3588 DDR blobs were added, Panthor firmware expanded to cover additional Mali GPUs, and a PCIe LTSSM timeout fix improves cold-boot NVMe detection on Rockchip. NanoPC-T6 LTS Plus was renamed, panther-x2 moved from CSC to EOS, and odroidxu4-current advanced to 6.6.138. In the build framework, an unsafe eval was replaced with declare -g and namerefs, destructive commands were properly quoted, and Docker --privileged is now gated behind an explicit DOCKER_PRIVILEGED toggle. The desktop configuration tree migrated to the armbian-config module_desktops system, kernel build failures now propagate exit codes correctly, missing BOOT_FDT_FILE surfaces as an error alert, and SysRq-via-BREAK was restored on dw-apb-uart for mvebu-6.18 and rockchip64-7.0 kernels. #Armbian #EmbeddedLinux #UBoot #Rockchip #SBC #LinuxKernel Changes(#9400 P1b) Replace unsafe eval with declare -g and nameref. by @iav in armbian/build#9461action: emit assets manifest JSON alongside release uploads. by @igorpecovnik in armbian/build#9772action: leave torrent URLs empty in per-image asset manifests. by @igorpecovnik in armbian/build#9792Add expect-dev to package dependencies. by @igorpecovnik in armbian/configng#904Add support for Photonicat2 board with USB hub watchdog. by @HackingGate in armbian/build#9765arm64: dts: rockchip: rename NanoPC-T6 LTS Plus to NanoPC-T6 Plus. by @igorpecovnik in armbian/linux-rockchip#478Build-Switches: document DOCKER_PRUNE opt-in. by @igorpecovnik in armbian/documentation#920build: misc cleanup — DEBUG-gated mmdebstrap verbosity, DOCKER_PRUNE opt-in. by @igorpecovnik in armbian/build#9704chore(config/common): remove dead FAST_CREATE_IMAGE variable. by @iav in armbian/build#9756ci/maintenance-unit-tests: skip draft PRs. by @igorpecovnik in armbian/configng#910ci: add Maintenance: Watchdog workflow. by @igorpecovnik in armbian/docker-armbian-build#23ci: add Ubuntu resolute to the build matrix. by @igorpecovnik in armbian/sdk#22ci: aggregate per-cell asset manifests into armbian-sdk-images.json. by @igorpecovnik in armbian/sdk#13ci: cancel in-flight download-index runs when a new one starts. by @igorpecovnik in armbian/armbian.github.io#313ci: dispatch armbian.github.io download-index regen after green build. by @igorpecovnik in armbian/sdk#21ci: dispatch armbian/website sync after web-directory generation. by @igorpecovnik in armbian/armbian.github.io#310ci: fix dispatch chain — download-index fan-out + redirector ends with directory regen. by @igorpecovnik in armbian/armbian.github.io#311ci: rename build workflow to 'Docker Images For Automation'. by @igorpecovnik in armbian/docker-armbian-build#24Community: blacklist xpressreal-t3 (resolute desktops failing). by @igorpecovnik in armbian/armbian.github.io#308Community: enable Ubuntu minimal CLI for all boards (not just headless). by @igorpecovnik in armbian/armbian.github.io#309desktops: migrate from config/desktop/ tree to armbian-config module_desktops. by @igorpecovnik in armbian/build#9683Disable UDev Rule for Radxa Display 10 FHD. by @FlorianKohn in armbian/build#9503docker: gate --privileged behind DOCKER_PRIVILEGED toggle (default yes). by @iav in armbian/build#9733docs: add extensions reference list. by @iav in armbian/documentation#881feat(boards/helios4): enable watchdog extension by default. by @iav in armbian/build#9757Fix cmdline fsck argument. by @QwaSeeK in armbian/build#9779Fix rk3528 nanopi zero2 snps reset gpio property. by @EvilOlaf in armbian/build#9770fix(config): skip host filesystem compatibility check for ROOTFS_TYPE=nfs. by @iav in armbian/build#9759fix(kernel/mvebu-6.18): restore SysRq-via-BREAK on dw-apb-uart (8250_dw). by @iav in armbian/build#9760fix(kernel/rockchip64-7.0): restore SysRq-via-BREAK on dw-apb-uart (8250_dw). by @iav in armbian/build#9750framework: add resolute (Ubuntu 26.04) image to the daily matrix. by @igorpecovnik in armbian/docker-armbian-build#26helios4: bump u-boot to v2026.04. by @iav in armbian/build#9786image/compress-checksum: maximize CPU + memory use. by @igorpecovnik in armbian/build#9758Introduce bleedingedge BRANCH for rockchip64. by @EvilOlaf in armbian/build#9738kernel-dtb: surface missing BOOT_FDT_FILE as err alert (fixes #8083). by @iav in armbian/build#9700kernel: fix process not exit with kernel build failure. by @amazingfate in armbian/build#9771manage_zsh → module_zsh: align with current module style. by @igorpecovnik in armbian/configng#911Merge third-party armbian-images.json sources into the main download index. by @igorpecovnik in armbian/armbian.github.io#306meson64: introduce bleedingedge BRANCH with 7.1-rc2. by @EvilOlaf in armbian/build#9761nanopi-m5: mainline U-Boot v2026.04 + UFS (vendor-SPL hybrid). by @SuperKali in armbian/build#9788Nightly: blacklist 16 boards failing resolute+gnome_desktop. by @igorpecovnik in armbian/armbian.github.io#307panther-x2: move from CSC to EOS. by @igorpecovnik in armbian/build#9778panthor: Add firmware for more Mali GPUs. by @nyanmisaka in armbian/firmware#124pci: pcie_dw_rockchip: increase PCIe LTSSM timeout for cold boot NVMe. by @rpahle in armbian/build#9751Pre-load SDK images with build framework, code-server, Python + Claude Code, and SSH keys. by @igorpecovnik in armbian/sdk#16prepare-host: support Ubuntu resolute's qemu-user packaging changes. by @igorpecovnik in armbian/build#9790Quote variables in destructive commands (#9400 P0). by @iav in armbian/build#9401README: cover both image families this repo publishes. by @igorpecovnik in armbian/docker-armbian-build#25reporting-release-summary: prepend 'Armbian' to digest titles. by @igorpecovnik in armbian/armbian.github.io#305Revert zsh integration from SDK image. by @igorpecovnik in armbian/sdk#23rk3576: Add SPL v1.08 blob. by @SuperKali in armbian/rkbin#44RK3588: Add v1.20 DDR blob. by @HeyMeco in armbian/rkbin#43Rock-5B-Plus and Rock-5T: Move to u-boot 2026.04. by @HeyMeco in armbian/build#9773SpacemiT: Update EDGE branch to linux-7.1. by @pyavitz in armbian/build#9784Surface armbian-sdk images in Dedicated Applications. by @igorpecovnik in armbian/website#19Update odroidxu4-current to 6.6.137. by @belegdol in armbian/build#9768Update odroidxu4-current to 6.6.138. by @belegdol in armbian/build#9793Update README to clarify Armbian SDK purpose. by @igorpecovnik in armbian/sdk#18Update USB version in odroidhc4.conf. by @igorpecovnik in armbian/build#9754userpatches: install zsh via armbian-config --api, not direct apt. by @igorpecovnik in armbian/sdk#20userpatches: pre-install gh + first-boot provisioning stub. by @igorpecovnik in armbian/sdk#14userpatches: pre-install tig, nodejs and Claude Code CLI host-side. by @igorpecovnik in armbian/sdk#17userpatches: pre-install zsh in the chroot. by @igorpecovnik in armbian/sdk#19userpatches: switch pre-install from gh to git. by @igorpecovnik in armbian/sdk#15View the full article
  11. This week's work centers on release and CI infrastructure, board and U-Boot updates, and build framework hardening. On the release pipeline, asset manifest JSON is now emitted alongside uploads, third-party armbian-images.json sources are merged into the main download index, and dispatch chains were rewired so that build completion fans out cleanly to download-index regeneration and website sync. Ubuntu resolute (26.04) entered the daily build matrix, with corresponding prepare-host adjustments for its qemu-user packaging and a targeted blacklist for boards failing resolute plus GNOME. The new Armbian SDK images are now surfaced on the website and ship preloaded with the build framework, code-server, and developer tooling. On the platform side, U-Boot v2026.04 lands for Helios4, Rock-5B-Plus, Rock-5T, and NanoPi-M5 (with mainline UFS via a vendor-SPL hybrid), while new bleedingedge branches were introduced for rockchip64 and meson64. Initial support arrived for the Photonicat2 board, new RK3576 SPL and RK3588 DDR blobs were added, Panthor firmware expanded to cover additional Mali GPUs, and a PCIe LTSSM timeout fix improves cold-boot NVMe detection on Rockchip. NanoPC-T6 LTS Plus was renamed, panther-x2 moved from CSC to EOS, and odroidxu4-current advanced to 6.6.138. In the build framework, an unsafe eval was replaced with declare -g and namerefs, destructive commands were properly quoted, and Docker --privileged is now gated behind an explicit DOCKER_PRIVILEGED toggle. The desktop configuration tree migrated to the armbian-config module_desktops system, kernel build failures now propagate exit codes correctly, missing BOOT_FDT_FILE surfaces as an error alert, and SysRq-via-BREAK was restored on dw-apb-uart for mvebu-6.18 and rockchip64-7.0 kernels. #Armbian #EmbeddedLinux #UBoot #Rockchip #SBC #LinuxKernel Changes(#9400 P1b) Replace unsafe eval with declare -g and nameref. by @iav in armbian/build#9461action: emit assets manifest JSON alongside release uploads. by @igorpecovnik in armbian/build#9772action: leave torrent URLs empty in per-image asset manifests. by @igorpecovnik in armbian/build#9792Add expect-dev to package dependencies. by @igorpecovnik in armbian/configng#904Add support for Photonicat2 board with USB hub watchdog. by @HackingGate in armbian/build#9765arm64: dts: rockchip: rename NanoPC-T6 LTS Plus to NanoPC-T6 Plus. by @igorpecovnik in armbian/linux-rockchip#478Build-Switches: document DOCKER_PRUNE opt-in. by @igorpecovnik in armbian/documentation#920build: misc cleanup — DEBUG-gated mmdebstrap verbosity, DOCKER_PRUNE opt-in. by @igorpecovnik in armbian/build#9704chore(config/common): remove dead FAST_CREATE_IMAGE variable. by @iav in armbian/build#9756ci/maintenance-unit-tests: skip draft PRs. by @igorpecovnik in armbian/configng#910ci: add Maintenance: Watchdog workflow. by @igorpecovnik in armbian/docker-armbian-build#23ci: add Ubuntu resolute to the build matrix. by @igorpecovnik in armbian/sdk#22ci: aggregate per-cell asset manifests into armbian-sdk-images.json. by @igorpecovnik in armbian/sdk#13ci: cancel in-flight download-index runs when a new one starts. by @igorpecovnik in armbian/armbian.github.io#313ci: dispatch armbian.github.io download-index regen after green build. by @igorpecovnik in armbian/sdk#21ci: dispatch armbian/website sync after web-directory generation. by @igorpecovnik in armbian/armbian.github.io#310ci: fix dispatch chain — download-index fan-out + redirector ends with directory regen. by @igorpecovnik in armbian/armbian.github.io#311ci: rename build workflow to 'Docker Images For Automation'. by @igorpecovnik in armbian/docker-armbian-build#24Community: blacklist xpressreal-t3 (resolute desktops failing). by @igorpecovnik in armbian/armbian.github.io#308Community: enable Ubuntu minimal CLI for all boards (not just headless). by @igorpecovnik in armbian/armbian.github.io#309desktops: migrate from config/desktop/ tree to armbian-config module_desktops. by @igorpecovnik in armbian/build#9683Disable UDev Rule for Radxa Display 10 FHD. by @FlorianKohn in armbian/build#9503docker: gate --privileged behind DOCKER_PRIVILEGED toggle (default yes). by @iav in armbian/build#9733docs: add extensions reference list. by @iav in armbian/documentation#881feat(boards/helios4): enable watchdog extension by default. by @iav in armbian/build#9757Fix cmdline fsck argument. by @QwaSeeK in armbian/build#9779Fix rk3528 nanopi zero2 snps reset gpio property. by @EvilOlaf in armbian/build#9770fix(config): skip host filesystem compatibility check for ROOTFS_TYPE=nfs. by @iav in armbian/build#9759fix(kernel/mvebu-6.18): restore SysRq-via-BREAK on dw-apb-uart (8250_dw). by @iav in armbian/build#9760fix(kernel/rockchip64-7.0): restore SysRq-via-BREAK on dw-apb-uart (8250_dw). by @iav in armbian/build#9750framework: add resolute (Ubuntu 26.04) image to the daily matrix. by @igorpecovnik in armbian/docker-armbian-build#26helios4: bump u-boot to v2026.04. by @iav in armbian/build#9786image/compress-checksum: maximize CPU + memory use. by @igorpecovnik in armbian/build#9758Introduce bleedingedge BRANCH for rockchip64. by @EvilOlaf in armbian/build#9738kernel-dtb: surface missing BOOT_FDT_FILE as err alert (fixes #8083). by @iav in armbian/build#9700kernel: fix process not exit with kernel build failure. by @amazingfate in armbian/build#9771manage_zsh → module_zsh: align with current module style. by @igorpecovnik in armbian/configng#911Merge third-party armbian-images.json sources into the main download index. by @igorpecovnik in armbian/armbian.github.io#306meson64: introduce bleedingedge BRANCH with 7.1-rc2. by @EvilOlaf in armbian/build#9761nanopi-m5: mainline U-Boot v2026.04 + UFS (vendor-SPL hybrid). by @SuperKali in armbian/build#9788Nightly: blacklist 16 boards failing resolute+gnome_desktop. by @igorpecovnik in armbian/armbian.github.io#307panther-x2: move from CSC to EOS. by @igorpecovnik in armbian/build#9778panthor: Add firmware for more Mali GPUs. by @nyanmisaka in armbian/firmware#124pci: pcie_dw_rockchip: increase PCIe LTSSM timeout for cold boot NVMe. by @rpahle in armbian/build#9751Pre-load SDK images with build framework, code-server, Python + Claude Code, and SSH keys. by @igorpecovnik in armbian/sdk#16prepare-host: support Ubuntu resolute's qemu-user packaging changes. by @igorpecovnik in armbian/build#9790Quote variables in destructive commands (#9400 P0). by @iav in armbian/build#9401README: cover both image families this repo publishes. by @igorpecovnik in armbian/docker-armbian-build#25reporting-release-summary: prepend 'Armbian' to digest titles. by @igorpecovnik in armbian/armbian.github.io#305Revert zsh integration from SDK image. by @igorpecovnik in armbian/sdk#23rk3576: Add SPL v1.08 blob. by @SuperKali in armbian/rkbin#44RK3588: Add v1.20 DDR blob. by @HeyMeco in armbian/rkbin#43Rock-5B-Plus and Rock-5T: Move to u-boot 2026.04. by @HeyMeco in armbian/build#9773SpacemiT: Update EDGE branch to linux-7.1. by @pyavitz in armbian/build#9784Surface armbian-sdk images in Dedicated Applications. by @igorpecovnik in armbian/website#19Update odroidxu4-current to 6.6.137. by @belegdol in armbian/build#9768Update odroidxu4-current to 6.6.138. by @belegdol in armbian/build#9793Update README to clarify Armbian SDK purpose. by @igorpecovnik in armbian/sdk#18Update USB version in odroidhc4.conf. by @igorpecovnik in armbian/build#9754userpatches: install zsh via armbian-config --api, not direct apt. by @igorpecovnik in armbian/sdk#20userpatches: pre-install gh + first-boot provisioning stub. by @igorpecovnik in armbian/sdk#14userpatches: pre-install tig, nodejs and Claude Code CLI host-side. by @igorpecovnik in armbian/sdk#17userpatches: pre-install zsh in the chroot. by @igorpecovnik in armbian/sdk#19userpatches: switch pre-install from gh to git. by @igorpecovnik in armbian/sdk#15View the full article
  12. I just checked and Orange Pi 5 is capable of DP mode over usb-c. I assume that patch has been tested and if it works (I might test it myself some time in near future) it is worth to keep.
  13. Quite a while ago I added GPIO names to the rock-3a. Perhaps you can get an idea how to do this. Source: https://docs.radxa.com/en/rock3/rock3a/hardware-design/hardware-interface#gpio-interface Implementation: https://github.com/armbian/build/pull/7403/changes
  14. @Gwainer try these images https://github.com/NickAlilovic/build/releases/tag/20250306
  15. @SecLyzer You can find everything you need here
  16. I created this account just to thank you, man. Thank you so much, it worked perfectly here. Finally, my old TV box has another use besides collecting dust.
  17. Last week
  18. Bump to uboot 2026.04 tested with kernel 7.0.5 no mods, just pure mainline Boot Logs: https://paste.armbian.com/ujumalanuc Github Pull request: https://github.com/armbian/build/pull/9807 Tested with kernel 7.0.6 Boot Logs: https://paste.armbian.com/jabokoqusa
  19. extraargs=nvme_core.default_ps_max_latency_us=0 pcie_aspm=off pcie_port_pm=off to /boot/armbianEnv.txt fixes nvme detection the temperature is echo "$(( $(cat /sys/class/hwmon/hwmon0/temp1_input) / 1000 )) °C" if you copy the system to nvme and wanna boot with microsd (spi doesn't work for now): 1) it will actually boot but without boot mountpoint 2) mount /boot and /media/mmcboot manually 3) fix fstab
  20. Wrote a PR to remedy the situation https://github.com/armbian/build/pull/9800
  21. ok my findings root@rk3318-box:/boot# cat *Env.txt verbosity=1 bootlogo=true console=both overlay_prefix=rockchip fdtfile=rockchip/rk3318-box.dtb rootdev=UUID=a3e848f3-8d54-412d-9184-5bc40ab76686 rootfstype=ext4 overlays=hdmi-audio rk3318-box-cpu-hs rk3318-box-led-conf1 rk3318-box-wlan-ap6334 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u root@rk3318-box:/boot# sudo ln -s /usr/lib/firmware/brcm/brcmfmac4334-sdio.bin /usr/lib/firmware/brcm/brcmfmac4334-sdio.rockchip,rk3318-box.bin ### it was missing according the log sudo rm /usr/lib/firmware/brcm/brcmfmac4334-sdio.rockchip,rk3318-box.txt ### this one did not do the job , you could ofcourse backup ... sudo wget -O /usr/lib/firmware/brcm/brcmfmac4334-sdio.rockchip,rk3318-box.txt https://pastebin.com/raw/00gLSkKS ### the nvram hosted in this topic after the reboot the wifi worked fine for me
  22. Please note that it is a known issue that Turnip / Vulkan broken on Snapdragon SM8550 / Adreno 740 on Mesa 25.3.x. See https://gitlab.freedesktop.org/mesa/mesa/-/work_items/14656 The workaround is to apply patch from https://github.com/batocera-linux/batocera.linux/blob/master/board/batocera/patches/mesa3d/001-fix-freedreno-vulkan.patch and rebuild 001-fix-freedreno-vulkan.patch
  23. duplicate https://forum.armbian.com/topic/59601-sd-card-boot-cant-find-my-sda1hdd-after-warning-and-fsck/?do=findComment&comment=237240
  24. That's default Debian behavior. Ubuntu includes sbin in PATH afaik. In any case Armbian does not alter this.
  25. Hi guys, I too have one of these paperweights I'd like to use for a real HA instance to have as a backup if my actual server takes a dump. I was hoping for root access as I'm not a novice when it comes to custom bootloader and roms on other devices but this is a whole different monster. Any tips would be appreciated.
  26. Just as an update, for anyone who cares. The above setup worked well, but I couldn't help but attempting to get video hardware acceleration in a browser. Since my post above, Armbian support for the Nanopi R6S went platinum (thanks to @Efe Çetin), kernel 7 came out and mesa 26 should provide all that is needed for vaapi/v4l2 support in firefox. Unfortunately, minimal Armbian Debian with kernel 7 combined with mesa 26 looks to be some time away - that would allow me to run sway, and likely with firefox using video decode acceleration. OTOH, vendor kernel at 6.1 doesn't seem to allow sway to run at all. So I tried Armbian Debian 13 minimal with kernel 6.18, which runs sway just fine, but the mesa version is stuck at 25.2 which in the standard Debian package does not by default support the rockchip hardware yet, I think. In addition, there seems to be some incompatibility with the repository provided here (or I am doing something wrong, which I wouldn't deny). Fortunately, looking at the Armbian git files I saw that the standard Armbian Ubuntu Noble with vendor 6.1 and Gnome (KDE version doesn't run well) appears to a) work fine with wayland, and b) automatically uses the Amazingfate (liujianfeng1994) PPA. This provides chromium with video hardware decode support, and I can still set up jellyfin. So at this point, without having to compile everything myself from scratch, this is the best setup from my perspective. Shout out to @Efe Çetin for making it this convenient - which it truly is, even though Gnome isn't my preferred DM.
