Hi Verner,
I tried this one on muy opi3
https://laet.pw/index.php/s/M2eXJKll5sdnlBN/download?path=%2F0808&files=Armbian_5.93_Orangepi3_Debian_buster_dev_5.2.6.img.gz
but it can't start.
there is a kernel panic:
U-Boot 2019.04-armbian (Aug 08 2019 - 07:28:48 +0000) Allwinner Technology
CPU:   Allwinner H6 (SUN50I)
Model: OrangePi 3
DRAM:  2 GiB
MMC:   mmc@4020000: 0, mmc@4022000: 1
Loading Environment from EXT4... ** File not found /boot/boot.env **
** Unable to read "/boot/boot.env" from mmc0:1 **
In:    serial@5000000
Out:   serial@5000000
Err:   serial@5000000
Net:   No ethernet found.
starting USB...
No controllers found
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
3042 bytes read in 2 ms (1.5 MiB/s)
## Executing script at 4fc00000
U-boot loaded from SD
Boot script loaded from mmc
181 bytes read in 1 ms (176.8 KiB/s)
27919 bytes read in 9 ms (3 MiB/s)
4161 bytes read in 5 ms (812.5 KiB/s)
Applying kernel provided DT fixup script (sun50i-h6-fixup.scr)
## Executing script at 44000000
8244348 bytes read in 835 ms (9.4 MiB/s)
14954504 bytes read in 1514 ms (9.4 MiB/s)
## Loading init Ramdisk from Legacy Image at 4fe00000 ...
   Image Name:   uInitrd
   Data Size:    8244284 Bytes = 7.9 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 4fa00000
   Booting using the fdt blob at 0x4fa00000
   Loading Ramdisk to 49823000, end 49fffc3c ... OK
   Loading Device Tree to 00000000497b3000, end 0000000049822fff ... OK
Starting kernel ...
[    6.356324] Unable to handle kernel NULL pointer dereference at virtual addr1
[    6.365113] Mem abort info:
[    6.367901]   ESR = 0x96000004
[    6.370951]   Exception class = DABT (current EL), IL = 32 bits
[    6.376861]   SET = 0, FnV = 0
[    6.379909]   EA = 0, S1PTW = 0
[    6.383043] Data abort info:
[    6.385918]   ISV = 0, ISS = 0x00000004
[    6.389746]   CM = 0, WnR = 0
[    6.392709] user pgtable: 4k pages, 48-bit VAs, pgdp=00000000b4bed000
[    6.399138] [0000000000000501] pgd=0000000000000000
[    6.404009] Internal error: Oops: 96000004 [#1] SMP
[    6.408877] Modules linked in: snd_soc_hdmi_codec snd_soc_core snd_pcm_dmaenx
[    6.428770] CPU: 2 PID: 514 Comm: haveged Not tainted 5.2.6-sunxi64 #5.93
[    6.435547] Hardware name: OrangePi 3 (DT)
[    6.439637] pstate: 40000085 (nZcv daIf -PAN -UAO)
[    6.444431] pc : account_user_time+0x18/0xd8
[    6.448695] lr : account_process_tick+0xf8/0x118
[    6.453304] sp : ffff000010013d80
[    6.456612] x29: ffff000010013d80 x28: ffff800077bb0228
[    6.461916] x27: ffff800077bafd00 x26: 0000000000000040
[    6.467220] x25: 0000000000000080 x24: 000000017a9bdad6
[    6.472524] x23: 0000000000000001 x22: 0000000000000001
[    6.477827] x21: 0000800066db4000 x20: 00000000003d0900
[    6.483131] x19: 0000000000000001 x18: 0000000000000000
[    6.488435] x17: 0000000000000000 x16: 0000000000000000
[    6.493739] x15: 0000000000000000 x14: 0000000000000000
[    6.499043] x13: 0000000000000000 x12: 0000000000000000
[    6.504346] x11: 0000000000000000 x10: 0000000000000040
[    6.509650] x9 : ffff000010e32a78 x8 : ffff000010e32a70
[    6.514954] x7 : ffff800075000290 x6 : 0000000010b2a35f
[    6.520258] x5 : 0000800066db4000 x4 : ffff000010e18000
[    6.525562] x3 : 0000000000000000 x2 : 00000000003d0900
[    6.530865] x1 : 00000000003d0900 x0 : 0000000000000001
[    6.536170] Call trace:
[    6.538614]  account_user_time+0x18/0xd8
[    6.542531]  account_process_tick+0xf8/0x118
[    6.546797]  update_process_times+0x20/0x58
[    6.550977]  tick_sched_handle.isra.5+0x30/0x48
[    6.555501]  tick_sched_timer+0x48/0x98
[    6.559331]  __hrtimer_run_queues+0xfc/0x218
[    6.563593]  hrtimer_interrupt+0xf8/0x2d0
[    6.567599]  arch_timer_handler_phys+0x28/0x40
[    6.572038]  handle_percpu_devid_irq+0x80/0x140
[    6.576564]  generic_handle_irq+0x24/0x38
[    6.580567]  __handle_domain_irq+0x5c/0xb0
[    6.584658]  gic_handle_irq+0x58/0xa8
[    6.588315]  el0_irq_naked+0x4c/0x54
[    6.591887] Code: a90153f3 aa0003f3 f90013f5 aa0103f4 (f9428000)
[    6.597972] ---[ end trace 51151885df76d1d1 ]---
[    6.602582] Kernel panic - not syncing: Fatal exception in interrupt
[    6.608929] SMP: stopping secondary CPUs
[    6.612846] Kernel Offset: disabled
[    6.616328] CPU features: 0x0002,20002004
[    6.620330] Memory Limit: none
[    6.623382] Rebooting in 10 seconds..
sorry... :(
Sorry to hear but no clue.
These images come directly from the build script located here https://github.com/armbian/build and I did not add any modifications. They are just pre-build to save some time setting up a build environment and run the whole thing. Maybe someone does not even have a chance to built such images themselves.
And also they are some kind of control as if something is missing there must have been a change that breaks the build process.
The support for the Allwinner H6 SoC (which is the heart of boards like the OrangePi One Plus, Lite2 and OrangePi 3) is still under development and dev images can break at any time for any reason. Feel free to give older images a try and if you find one that actually works let us know so we might be able to track the issue down.
Here you can find even older images: https://dl.armbian.com/orangepi3/
Hi Werner,
by chance, do you know how to tell the Armbian build script, to prepare for example an Armbian 5.88 with kernel 5.0.x for OPI3?
Now we are at 5.93 with kernel 5.2.6 but I would like to be able to compile builds with kernel of the 5.0.x series, because although sometimes they were hung and the audio does not work, at least they can be used.
Right now I'm using an old build to write to you, but I don't dare to update it in case something breaks.
This is working very well for me (only 5 days uptime due to local power outage - otherwise it "just works" :-)
In my case, with 5.2.0 built 3 weeks ago :
  ___  ____  _   _____
 / _ \|  _ \(_) |___ /
| | | | |_) | |   |_ \
| |_| |  __/| |  ___) |
 \___/|_|   |_| |____/
Welcome to Debian Stretch with Armbian Linux 5.2.0-sunxi64
System load:   0.08 0.02 0.01  	Up time:       3 days
Memory usage:  4 % of 1997MB 	IP:            169.254.8.74 10.111.111.81
CPU temp:      25°C
Usage of /:    21% of 7.1G
From a quick look there were three commits in the past 21 days besides commits directly to mainline.
https://github.com/armbian/build/commit/414f304b138a0cdd9ba9756b5201d61b7400fa05
https://github.com/armbian/build/commit/5412aa7d9c9406b084f5be07773e7d3ea107a2e6
https://github.com/armbian/build/commit/307c1daaa181151ea5b9c8e3507f145463fb82eb#diff-80b9f0b99e69776b772e470f0afc5e8c
The easiest to test is the added CPU_THERMAL function by simply trying an image that were made at least four days ago that does not include this most recent commit: https://laet.pw/index.php/s/M2eXJKll5sdnlBN?path=%2F0508
Other is more difficult to figure out what has been changed to cause break.
On 8/4/2019 at 8:11 PM, Werner said:
I added OPi 3 Buster image as well as kernel debs to my builds and will be available tomorrow following the link mentioned in my signature below.
Did you have any luck with BT support?
https://megous.com/git/linux/commit/?h=opi3-5.2&id=9c296799c4d3dd90986833cfded392098c1979bd
I tried that but after all the steps it did not work at the end. And I could never figure out what I did wrong.
I do not own this board, so sorry, no clue. I just provide pre-built images to save others some time building their own.
Any idea how to make HDMI sound work? I added LibreElec sound patch for OPi3 (https://github.com/LibreELEC/LibreELEC.tv/blob/master/projects/Allwinner/devices/H6/patches/linux/05-sound-hack.patch) to "patch/kernel/sunxi-dev/sound-hack.patch" and built desktop stretch image with Kernel 5.2.8. Patch was applied successfully as mentioned on the trailing log of building process. System boots to xfce4 and I see HDMI Analog Sound device in Pulse Audio Manager and AlsaMixer but I don't get sound. I notice poor graphics when sound patch is applied. May be I am missing something..... help will be appreciated.
When we getting Sound from Armbian by the way? :)
27 minutes ago, jernej said:
Try to apply also projects/Allwinner/patches/linux/0001-hdmi-sound-improvements.patch
Just tried but failed while compiling..... "[ failed ]" while the other patch was still applied before this. Anything to do with changing order of both sound patches?
Maybe or it could also be that Armbian already includes some patches which are in conflict with those.
Tried the following image, unable to boot and ended up with this message:
[ OK ] Started Armbian hardware optimization.
_
Armbian_5.93_Orangepi3_Ubuntu_bionic_dev_5.2.8_desktop.img
Armbian_5.93_Orangepi3_Ubuntu_bionic_next_4.19.66.img
Armbian_5.93_Orangepi3_Debian_buster_dev_5.2.8_desktop.img
Armbian_5.88_Orangepi3_Ubuntu_bionic_dev_5.1.7.img
Armbian_5.90.190705_Orangepi3_Ubuntu_bionic_dev_5.1.15.img
Armbian_5.90_Orangepi3_Debian_buster_dev_5.1.15.img
Armbian_5.90_Orangepi3_Ubuntu_bionic_dev_5.1.15.img
https://www.aliexpress.com/item/32969768551.html?spm=a2g0s.9042311.0.0.48ae4c4dJolXaF
SBC: OrangePi 3 2GB DDR3 + 8GB eMMC + 5V 3A adapter
Previously successful image that can boot is back at March:
Armbian_5.77_Orangepi3_Ubuntu_bionic_dev_5.0.1_desktop.img
i am not the only one affected, right?
_
I used Buster... I felt some stability issues but it booted fine.  Before that couple of June versions also worked for me..... Check your SDcard....with some cheap cards I felt issues with Balena but same cards Win32DiskImager worked.... I don't think I was super lucky to have Buster booted for me only.... :)
I used three different SDs card but it still can't boot up.
If i can use the same SD card with another image to boot up in another board, does it prove that the SD card is fine?
I plan to switch from Etcher to Win32DiskImager, switch from SanDisk/Kingston to Samsung. See whichever solves it.
Note that I have yet to flash the board. It's still running the Android image that it came with. The adapter came with the set that OrangePi sold with the board.
Good luck....awaiting update!
_
You need to change the DTB file to version 5.88.190601 - 5.1.5
Located on the SD card: /boot/dtb-5.1.7-sunxi64/allwinner/sun50i-h6-orangepi-3.dtb
That fixed it for me on 5.88 dev 5.17.
Version linux-dtb-dev-sunxi64 version 5.90.190630 should work too, but I've not tested it.
Check post:
Hi guys,
Can you make it clear about Sunxi-Cedrus, please:
According to information here Cedrus for H6 and Lima/Panfrost drivers were merged into 5.2 linux kernel. Does this mean that when Armbian will be switched to 5.2.y,  it will be possible to HW decode H.264 using FFMPEG? Or everything is more complicated?)
Later is true. While Panfrost is merged in 5.2, it doesn't support Mali T720 yet, which is present in H6. It's true that Cedrus is in kernel, but currently only supports decoding MPEG2. Very basic support for H.264 will come with 5.3. On top of that, interface to this type of drivers (Cedrus is first of it's kind, RK VPU drivers being second) is not stable and thus not exposed in kernel API. Because of that no userspace program officially supports it, although ffmpeg fork exist which implements support for them.
Thanks for clarifying, jernej
