pisach Posted August 3, 2018 Share Posted August 3, 2018 1 hour ago, TheMojoMan said: Hi, I am running Armbian_5.44_S9xx_Ubuntu_bionic_3.14.29_mate_20180729 on my Mecool M8S Pro W (S905W) which boots without a dtb.img file. I have opened the box to find out that it has a SV6051P wifi chip. So, I followed the instructions by pisach on page 52: After reboot the list of local wifi access points are shown by the network-manager app! But when I select my network and enter the password it only changes the icon for about 30 seconds showing that it tries to connect. But it always fails to connect ... Here is the output of iwconfig: wlan0 IEEE 802.11bgn ESSID:off/any Mode:Managed Access Point: Not-Associated Tx-Power=20 dBm Retry short limit:7 RTS thr:off Fragment thr:off Power Management:off Can you please help me? You can send here output from dmesg or/and syslog. Link to comment Share on other sites More sharing options...
balbes150 Posted August 3, 2018 Author Share Posted August 3, 2018 1 hour ago, Reddwarf said: There is no external connection point, but I remember reading that you can solder on a cable on the board if you remove the lid from the box. Do you know anything about that? If not I have to investigate further, but I know it is possible at least with the Mini M8S. Many TV boxes on the Board have contacts for UART connection to which you can solder the wires to connect the USB-UART Converter.. You need to look at the surface of the Board or search the Internet ready description. Link to comment Share on other sites More sharing options...
Reddwarf Posted August 3, 2018 Share Posted August 3, 2018 4 minutes ago, balbes150 said: Many TV boxes on the Board have contacts for UART connection to which you can solder the wires to connect the USB-UART Converter.. You need to look at the surface of the Board or search the Internet ready description. Will do Is there a good windows program to capture the output that I can download and use? I will connest toe UART outut to a RS232 -> USB converter onnected to a PC... Link to comment Share on other sites More sharing options...
TheMojoMan Posted August 3, 2018 Share Posted August 3, 2018 1 hour ago, pisach said: You can send here output from dmesg or/and syslog. Hello pisach, thank you so much for your help! I saw there are a ton of errors regarding SV6XXX in dmesg ... dmesg.txt syslog.txt Link to comment Share on other sites More sharing options...
pisach Posted August 3, 2018 Share Posted August 3, 2018 1 hour ago, Reddwarf said: Will do Is there a good windows program to capture the output that I can download and use? I will connest toe UART outut to a RS232 -> USB converter onnected to a PC... like this :-) 1 Link to comment Share on other sites More sharing options...
Reddwarf Posted August 3, 2018 Share Posted August 3, 2018 1 minute ago, pisach said: like this :-) Something like that yes Link to comment Share on other sites More sharing options...
pisach Posted August 3, 2018 Share Posted August 3, 2018 1 hour ago, TheMojoMan said: Aug 3 21:11:51 localhost wpa_supplicant[3329]: dbus: fill_dict_with_properties dbus_interface=fi.w1.wpa_supplicant1.Interface dbus_property=Stations getter failed Aug 3 21:11:51 localhost wpa_supplicant[3329]: dbus: wpa_dbus_get_object_properties: failed to get object properties: (none) none Aug 3 21:11:51 localhost wpa_supplicant[3329]: dbus: Failed to construct signal Aug 3 21:11:51 localhost wpa_supplicant[3329]: dbus: fill_dict_with_properties dbus_interface=fi.w1.wpa_supplicant1.Interface dbus_property=Stations getter failed Aug 3 21:11:51 localhost NetworkManager[3367]: <info> [1533323511.5977] device (wlan0): supplicant interface state: starting -> ready Aug 3 21:11:51 localhost NetworkManager[3367]: <info> [1533323511.5981] device (wlan0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed') I'm not expert here, but it looks as WPA related. Are you sure that you actually use WPA and not something else? The WiFi driver seems OK, check your WiFi settings. Link to comment Share on other sites More sharing options...
TheMojoMan Posted August 3, 2018 Share Posted August 3, 2018 19 minutes ago, pisach said: I'm not expert here, but it looks as WPA related. Are you sure that you actually use WPA and not something else? The WiFi driver seems OK, check your WiFi settings. Thank you so much for your analysis! I always use WPA/WPA2 Personal to connect to my router. I think I compared the WiFi settings to the settings of my laptop running Manjaro (Arch) Linux before. But I will recheck again tomorrow. Link to comment Share on other sites More sharing options...
Rosimildo Posted August 4, 2018 Share Posted August 4, 2018 HI all, I've got a X96mini box, and I'd like to get Armbian with 4.18 running on it. Could you tell me which version works ? I just need a headless device for now. Thanks, Rosimildo. Link to comment Share on other sites More sharing options...
Rosimildo Posted August 4, 2018 Share Posted August 4, 2018 3 hours ago, Rosimildo said: HI all, I've got a X96mini box, and I'd like to get Armbian with 4.18 running on it. Could you tell me which version works ? I just need a headless device for now. Thanks, Rosimildo. I was able to install: This image works: Armbian_5.44_S9xxx_Ubuntu_bionic_3.14.29_mate_20180729.img But, I have been unable to get any 4.18 kernel to load correctly. I have read on this thread that some folks did it! Please share more info, thanks! R Link to comment Share on other sites More sharing options...
jeanrhum Posted August 5, 2018 Share Posted August 5, 2018 16 hours ago, Rosimildo said: HI all, I've got a X96mini box, and I'd like to get Armbian with 4.18 running on it. Could you tell me which version works ? I just need a headless device for now. Thanks, Rosimildo. I booted with 4.18 on my X96 mini as I claimed here: I just downloaded latest 5.44 image (was the 20180727) from link provided in 1rst post of this topic. Then burnt it to an sdcard and use the dtb for p281 (copy it and rename it as dtb.img at the root of the fat partition as explained on the 1rst post). Link to comment Share on other sites More sharing options...
Rosimildo Posted August 5, 2018 Share Posted August 5, 2018 9 hours ago, jeanrhum said: I booted with 4.18 on my X96 mini as I claimed here: I just downloaded latest 5.44 image (was the 20180727) from link provided in 1rst post of this topic. Then burnt it to an sdcard and use the dtb for p281 (copy it and rename it as dtb.img at the root of the fat partition as explained on the 1rst post). Thank you!!! I made a stupid mistake. I changed the name of the dtb as: 281.dtb !!! Naming it as it should: dtb.img, it worked! R Link to comment Share on other sites More sharing options...
Reddwarf Posted August 7, 2018 Share Posted August 7, 2018 @balbes150 I really enjoy the Test.mp4 music videos you attach to the various images, could you please upload all of them to a folder under Armbian so we can download them? Please? Link to comment Share on other sites More sharing options...
balbes150 Posted August 8, 2018 Author Share Posted August 8, 2018 12 hours ago, Reddwarf said: I really enjoy the Test.mp4 music videos you attach to the various images, could you please upload all of them to a folder under Armbian so we can download them? Please? Alas, I do not archive all versions of the files used. If you want, you can find all the videos used in the images on youtube. Link to comment Share on other sites More sharing options...
Reddwarf Posted August 8, 2018 Share Posted August 8, 2018 4 hours ago, balbes150 said: Alas, I do not archive all versions of the files used. If you want, you can find all the videos used in the images on youtube. Yeah, but I don't know the names.... Link to comment Share on other sites More sharing options...
ramawatar Posted August 10, 2018 Share Posted August 10, 2018 Can't wifi configuration model tanix tx3 all armbian img 3.14.29 kernelAnd librelaac 9.0 arm all wifi losshttps://uploads.tapatalk-cdn.com/20180810/c5b0f67f55a1aa95707e3709bce177ff.jpg Link to comment Share on other sites More sharing options...
rizapn Posted August 11, 2018 Share Posted August 11, 2018 Hi, I just start following this topics. I try to search for device zte B860H and found nothing. I try to follow the instruction (to run armbian) using my zte B860H STB, without any success. Does anyone here has the same STB model with me? Any clue to get it working? Thank you, Link to comment Share on other sites More sharing options...
balbes150 Posted August 11, 2018 Author Share Posted August 11, 2018 Correction of search operation in Synaptic program. Remove from directory "/etc/apt/apt.conf.d" all files. Download the link two files and copy them to the directory "/etc/apt/apt.conf.d". Run Synaptic and update the package list. After these steps, the package search in Synaptic should work fine. https://yadi.sk/d/R8U9M-oM3a8M9r Link to comment Share on other sites More sharing options...
Tommy21 Posted August 11, 2018 Share Posted August 11, 2018 Correction of search operation in Synaptic program. Remove from directory "/etc/apt/apt.conf.d" all files. Download the link two files and copy them to the directory "/etc/apt/apt.conf.d". Run Synaptic and update the package list. After these steps, the package search in Synaptic should work fine. https://yadi.sk/d/R8U9M-oM3a8M9rWill this be fixed in future armbian images, or we will have to fix it every time new image is out? Link to comment Share on other sites More sharing options...
ennoente Posted August 16, 2018 Share Posted August 16, 2018 Have tested different versions, some work well on my box. But how can I enable or install pvr addons? if i always install over ssh, error Message addon can not start ..??? Link to comment Share on other sites More sharing options...
Reddwarf Posted August 16, 2018 Share Posted August 16, 2018 13 minutes ago, ennoente said: Have tested different versions, some work well on my box. But how can I enable or install pvr addons? if i always install over ssh, error Message addon can not start ..??? Addons?? Are you talking about Kodi? Link to comment Share on other sites More sharing options...
talraash Posted August 16, 2018 Share Posted August 16, 2018 1 hour ago, ennoente said: Have tested different versions, some work well on my box. But how can I enable or install pvr addons? if i always install over ssh, error Message addon can not start ..??? If you need full kodi functional and compatibility use libreelec... Link to comment Share on other sites More sharing options...
Novato Posted August 18, 2018 Share Posted August 18, 2018 On 7/27/2018 at 9:59 AM, chessplayer said: Hi guys, Armbian 5.44 with the 3.14.29 kernel is running quite well on my MeCool M8S Pro W box. In fact, there is just one issue, which is a bit annoying: the MAC address is "somewhat" random, meaning taht apparently after leaving it turned off for a while, the MAC address changes slightly (and in any case, it is very different from the one the box normally has (LibreELEC, Android Custom ROM, printed on the label ...)). As I mentioned a little further up, my device tree is taken from a CoreELEC SD card, which should be the same as the one to be found here for the 2GB version. According to this post, the dtb could be the problem, but that is the one I have. Therefore, I tried both of the following in /etc/network/interfaces: pre-up macchanger -m 00:ac:3f:75:c0:ff eth0 iface eth0 hwaddress ether 00:ac:3f:75:c0:ff But to no avail - it remains at 00:ac:2f:78:c0:ff and will probably become something else when I let the box rest for a few days. Any ideas how to overcome this issue? Thanks in advance and Cheers, chessplayer I do not know what happens to my Mecool M8S Pro W and M8S Plus W devices. I tried Armbian_5.44_S9xxx_Debian_stretch_3.14.29_xfce_20180729.img on a SanDisk MicroSD 16GB class 10. The initial promt of installation and was started normally (despite the password error, it was necessary to change) but unfortunately the system was not initialized. During execution I get a list of executions with "OK" and some with "FAILED" between them "Failed_to_start _Load_Kernel" or something like that. I probably have a problem with the kernel. But unfortunately I can not capture the log to post here. At some point I was generating an HDMI error, so I changed the resolution from 1920x1080 to 1080x720 in the HDMI.sh file as indicated at the beginning of this topic and apparently it was resolved, even then the system is still not able to boot. Please someone teach me how to view the complete log so I can share it here and anyone who has ever succeeded in a MecoSM M8S Plus W or M8S Pro W device, tell me which distro, dtb, and kernel you used to get a perfect startup. Link to comment Share on other sites More sharing options...
Novato Posted August 18, 2018 Share Posted August 18, 2018 I also tested some dtb's p281 (p218 / p21x) but unfortunately I did not succeed for system startup. Usually at the time that I should boot the System Boot, the screen gets some running logs but always progress. I wonder if recording a video clip could be beneficial. Link to comment Share on other sites More sharing options...
ramawatar Posted August 19, 2018 Share Posted August 19, 2018 Nice! Again, thank you for your work on these boxes. is wifi working for tx3 mini for you?Sent from my Redmi Note 4 using Tapatalk Link to comment Share on other sites More sharing options...
Reddwarf Posted August 19, 2018 Share Posted August 19, 2018 On 8/18/2018 at 4:30 PM, Felipe Junior said: I do not know what happens to my Mecool M8S Pro W and M8S Plus W devices. I tried Armbian_5.44_S9xxx_Debian_stretch_3.14.29_xfce_20180729.img on a SanDisk MicroSD 16GB class 10. The initial promt of installation and was started normally (despite the password error, it was necessary to change) but unfortunately the system was not initialized. During execution I get a list of executions with "OK" and some with "FAILED" between them "Failed_to_start _Load_Kernel" or something like that. I probably have a problem with the kernel. But unfortunately I can not capture the log to post here. At some point I was generating an HDMI error, so I changed the resolution from 1920x1080 to 1080x720 in the HDMI.sh file as indicated at the beginning of this topic and apparently it was resolved, even then the system is still not able to boot. Please someone teach me how to view the complete log so I can share it here and anyone who has ever succeeded in a MecoSM M8S Plus W or M8S Pro W device, tell me which distro, dtb, and kernel you used to get a perfect startup. I also get the "Failed to start load kernel modules" and "failed to initialize zram..." on every image I try, but the 5.55 images run pretty well except for wifi which is a bit fluffy and BT support is absent. There is no video acceleration either.... Link to comment Share on other sites More sharing options...
Novato Posted August 19, 2018 Share Posted August 19, 2018 1 hour ago, Reddwarf said: I also get the "Failed to start load kernel modules" and "failed to initialize zram..." on every image I try, but the 5.55 images run pretty well except for wifi which is a bit fluffy and BT support is absent. There is no video acceleration either.... Interesting, what device are you doing in the tests? Do you have the same SoC s905W? And what versions of ARMBIAN 5.55 have you tried? Link to comment Share on other sites More sharing options...
Reddwarf Posted August 19, 2018 Share Posted August 19, 2018 1 minute ago, Felipe Junior said: Interesting, what device are you doing in the tests? Do you have the same SoC s905W? And what versions of ARMBIAN 5.55 have you tried? I'm using a Beelink mini MX-III, a mini M8S and a MXQPro+, the first two are 905 while the last is 905w. I have tried both xenial, bionic and debian stretch, the debian is the one that seems to work best. Link to comment Share on other sites More sharing options...
Novato Posted August 19, 2018 Share Posted August 19, 2018 11 minutes ago, Reddwarf said: I'm using a Beelink mini MX-III, a mini M8S and a MXQPro+, the first two are 905 while the last is 905w. I have tried both xenial, bionic and debian stretch, the debian is the one that seems to work best. Thanks for replying, I'm downloading the version Armbian_5.55_Aml-s9xxx_Debian_stretch_default_4.18.0_desktop_20180817.img to see if you have any changes. Link to comment Share on other sites More sharing options...
Novato Posted August 20, 2018 Share Posted August 20, 2018 I got this result with Armbian_5.37_S9xxx_Ubuntu_xenial_3.14.29_icewm_20171226.img on my Mecool M8S Pro 2G / 16 S912. This time there was no kernel error or ZRAM, but still did not complete Boot. See the last screen it performs. Link to comment Share on other sites More sharing options...
