balbes150 Posted July 27, 2018 Author Posted July 27, 2018 Updated images kernel 3.14 and 4.18. Add dtb for p281 (S905W). Please note that installation in eMMC, a system with kernel 4.18, is possible only when using u-boot-2018 and formatting the eMMC in normal disk mode. 1
KY69 Posted July 27, 2018 Posted July 27, 2018 Thank you so much for your effort and time. I see there are no (0727) images for icewm (yet). Do you plan to generate them too? They are the ones I have been testing...
chessplayer Posted July 27, 2018 Posted July 27, 2018 5 hours ago, balbes150 said: Add to the parameter string (in the file "uEnv.ini") parameter " mac=00:ac:3f:75:c0:ff" Thanks, @balbes150, that works! 1
balbes150 Posted July 28, 2018 Author Posted July 28, 2018 18 hours ago, KY69 said: Thank you so much for your effort and time. I see there are no (0727) images for icewm (yet). Do you plan to generate them too? They are the ones I have been testing... Yes. there is not enough time for everything By the way, interesting news, I managed to run the version of Manjaro on TV Box Amlogic, everything starts and works. But while it has to be done in semi-manual mode (i'm need to rebuild the new image with full support for TV boxes). I hope soon there will be another version of the Linux distribution (Manjaro) for the platform Amlogic. Spoiler https://forum.manjaro.org/c/manjaro-arm 1
balbes150 Posted July 28, 2018 Author Posted July 28, 2018 Interestingly ,the number of views of this theme exceeded 300 000 .... Turns out the anniversary ... 1
KY69 Posted July 28, 2018 Posted July 28, 2018 51 minutes ago, balbes150 said: there is not enough time for everything I understand and I am by no means requesting anything. I appreciate your time and work and just wanted to know if there would be such releases in the future. I am running the 3.14.29 icewm version from April 06 on a TX3 mini 2/16, and it is very stable and fast. This is so cool! I tried a couple images with 4.x kernels (4.14 and 4.16 if I am not mistaken), but if recall correctly only the 4.16 version worked on my TX3 mini, and for some reason I was not able to run the root partition from my USB HDD, so I postponed tests for lack of time. The 3.14 kernel version I am running right now is booting from the SD card but the root partition is on the USB hard disk. I am writing this post from my TX3 mini, thank you! 51 minutes ago, balbes150 said: ... I managed to run the version of Manjaro on TV Box Amlogic, everything starts and works. ... I hope soon there will be another version of the Linux distribution (Manjaro) for the platform Amlogic. Nice! Again, thank you for your work on these boxes.
Tommy21 Posted July 28, 2018 Posted July 28, 2018 I've tried Ubuntu using 4.18 kernel, does anyone know when the sound will be supported, maybe kernel 4.19? I've tried to play 1080p yt video using firefox, it runs smoother than before, but it's pointless to play it without sound. It's good to see Amlogic soc making progress in Linux kernel, hope they will fix everyting that needs to be fixed soon.
balbes150 Posted July 29, 2018 Author Posted July 29, 2018 Fix For wifi SSV6051. We need to replace the core with this option. https://yadi.sk/d/-2EhUoNP3ZgJjc
balbes150 Posted July 29, 2018 Author Posted July 29, 2018 New images on the website with kernel 3.14 on fixed wifi ssv6051 version (20180729). Add image IceWM 3.14 and 4.18
KY69 Posted July 29, 2018 Posted July 29, 2018 19 minutes ago, balbes150 said: New images on the website with kernel 3.14 on fixed wifi ssv6051 version (20180729). Add image IceWM 3.14 and 4.18 Thank you x2, again! Will DL both of them now and start testing the new images.
David Markey Posted July 29, 2018 Posted July 29, 2018 I'm having problems with 3.14.29 bionic and CEC. CEC was working with 16.04 but not bionic. And tips on how to get it to work?
jeanrhum Posted July 29, 2018 Posted July 29, 2018 Hi, Thanks for your excellent work, I tested last image (debian xfce) on x96mini 2/16 and it boots well using p281 dtb file. I'm writting this post from it: Linux aml 4.18.0-rc5-aml-s9xxx #16 SMP PREEMPT Fri Jul 27 20:02:44 MSK 2018 aarch64 GNU/Linux Here is some feedbacks about some (minor or not depending of usage) problems: - no sound from the av port even if pulseaudio shows some activities (tested with mpv test video and a youtube video within chromium browser) - wireless card is not recognized (nothing with lsmod and obviously nothing with iwconfig (only lo and eth0)) - videoplayback is not accelerated - no mali driver for 3d acceleration even if glxinfo doesn't report any error I didn't try to solve any of these issues and maybe some of them are easy to fix. I'll see if I have time for that in a near future. In conclusion, current usage is mainly as server even if desktop starts well.
talraash Posted July 29, 2018 Posted July 29, 2018 Spoiler As I already wrote about external players, for html5 player in the browser scaling is also extremely difficult task. The same video is played in full screen mode. The first is 360p and as you can see, a significant frames dropped. Second, 720p native screen resolution and frames dropped only at the moment of ui appearance. So for 1080p this is less relevant, but for 720p screen resolution, any video with a resolution of 720p is preferable, even more than video with a lower resolution in all image with kernel 3.14.29.
David Markey Posted July 29, 2018 Posted July 29, 2018 3 hours ago, David Markey said: I'm having problems with 3.14.29 bionic and CEC. CEC was working with 16.04 but not bionic. And tips on how to get it to work? it seems the kodi package has been compiled without cec support
David Markey Posted July 30, 2018 Posted July 30, 2018 20 hours ago, David Markey said: it seems the kodi package has been compiled without cec support @balbes150 do you have compile instructions for kodi anywhere
ramawatar Posted July 30, 2018 Posted July 30, 2018 When it will be available manjaro Sent from my Redmi Note 4 using Tapatalk
balbes150 Posted July 31, 2018 Author Posted July 31, 2018 21 hours ago, David Markey said: do you have compile instructions for kodi anywhere Install the mali7 packages and follow the standard instructions to build KODI under Ubuntu. 17 hours ago, ramawatar said: When it will be available manjaro Coming soon.
MOHAMMAD HADI Posted July 31, 2018 Posted July 31, 2018 On 6/10/2018 at 9:30 PM, MOHAMMAD HADI said: Hi @balbes150 can you include the wifi drivers and dvb drivers for kii pro ? The DVB drivers are maintained by afl1 here https://github.com/afl1/dvb_tv-aml He includes them in his fork of the kernel here https://github.com/afl1/linux-amlogic/tree/amlogic-3.14-nougat/drivers/amlogic/dvb-avl The wifi chipset is ampak ap6335 which combine Broadcom wifi chip and the Bluetooth chip Thanks @balbes150 any word on the dvb drivers ?
ennoente Posted July 31, 2018 Posted July 31, 2018 I have tested different versions on nand on beste works Armbian_5.41_S9xxx_Ubuntu_xenial_3.14.29_mate_20180225 Kodi 17.3. on KII pro Box. But i can not install tvheadend, pvr add-ones and if installable shows kodi error, What can I do?
David Markey Posted July 31, 2018 Posted July 31, 2018 11 hours ago, balbes150 said: Install the mali7 packages and follow the standard instructions to build KODI under Ubuntu. Coming soon. configure: error: unsupported native build platform: aarch64-unknown-linux-gnu how do i fix that @balbes150 could you update your kodi builds to fix cec support?
balbes150 Posted August 1, 2018 Author Posted August 1, 2018 16 hours ago, MOHAMMAD HADI said: any word on the dvb drivers ? I'm still busy with works with kernel 4.18, the test mode setting in eMMC. 12 hours ago, ennoente said: What can I do?  Use Libreelec. 12 hours ago, David Markey said: could you update your kodi builds to fix cec support?  I'm still busy with other work.
balbes150 Posted August 3, 2018 Author Posted August 3, 2018 Good news. I am finishing testing the Armbian installation with 4.18 kernel in eMMC on the models I have in stock (Khades VIM1 VIM2 , X96 mini etc). To complete the full cycle of tests and release images, I'm looking for volunteers to test the installation scripts on different hardware. A prerequisite for the test, the presence of a connected console UART, send me the startup log and perform preparatory operations for the test.
TheMojoMan Posted August 3, 2018 Posted August 3, 2018 On 7/29/2018 at 1:28 PM, balbes150 said: New images on the website with kernel 3.14 on fixed wifi ssv6051 version (20180729). Add image IceWM 3.14 and 4.18 Hi, I am running Armbian_5.44_S9xx_Ubuntu_bionic_3.14.29_mate_20180729 on my Mecool M8S Pro W (S905W) which boots without a dtb.img file. I have opened the box to find out that it has a SV6051P wifi chip. So, I followed the instructions by pisach on page 52: On 5/28/2018 at 10:48 AM, pisach said: mecool M8S pro has SV6051 WiFi. You need to do the following: ln -s /lib/firmware /usr/lib/firmware modprobe ssv6051 add ssv6051 in /etc/modules reboot After reboot the list of local wifi access points are shown by the network-manager app! But when I select my network and enter the password it only changes the icon for about 30 seconds showing that it tries to connect. But it always fails to connect ... Here is the output of iwconfig: wlan0 IEEE 802.11bgn ESSID:off/any Mode:Managed Access Point: Not-Associated Tx-Power=20 dBm Retry short limit:7 RTS thr:off Fragment thr:off Power Management:off Can you please help me?
Reddwarf Posted August 3, 2018 Posted August 3, 2018 2 hours ago, balbes150 said: Good news. I am finishing testing the Armbian installation with 4.18 kernel in eMMC on the models I have in stock (Khades VIM1 VIM2 , X96 mini etc). To complete the full cycle of tests and release images, I'm looking for volunteers to test the installation scripts on different hardware. A prerequisite for the test, the presence of a connected console UART, send me the startup log and perform preparatory operations for the test. I have MXQ Pro+ 4k (905W), Mini M8S and Mini MX-III boxes if it is possible to connect UART cable to these boxes I'd be happy to help you test BTW: Is it a bit ironic that the only box officially supported, Beelink X2, there is NO development going on.....
balbes150 Posted August 3, 2018 Author Posted August 3, 2018 37 minutes ago, TheMojoMan said: Can you please help me? I don't use WiFi , so I don't know how to help you. Kernel module and firmware working, may require additional configuration. 32 minutes ago, Reddwarf said: if it is possible to connect UART cable to these boxes I'd be happy to help you test If you have a connection UART, Show me the startup log of the standard Android or Armbian firmware with kernel 3.14 (until the user prompt appears).
Reddwarf Posted August 3, 2018 Posted August 3, 2018 1 minute ago, balbes150 said: If you have a connection UART, remove the startup log of the standard Android or Armbian firmware with kernel 3.14 (until the user prompt appears). There is no external connection point, but I remember reading that you can solder on a cable on the board if you remove the lid from the box. Do you know anything about that? If not I have to investigate further, but I know it is possible at least with the Mini M8S.
pisach Posted August 3, 2018 Posted August 3, 2018 1 hour ago, TheMojoMan said: Hi, I am running Armbian_5.44_S9xx_Ubuntu_bionic_3.14.29_mate_20180729 on my Mecool M8S Pro W (S905W) which boots without a dtb.img file. I have opened the box to find out that it has a SV6051P wifi chip. So, I followed the instructions by pisach on page 52: After reboot the list of local wifi access points are shown by the network-manager app! But when I select my network and enter the password it only changes the icon for about 30 seconds showing that it tries to connect. But it always fails to connect ... Here is the output of iwconfig: wlan0 IEEE 802.11bgn ESSID:off/any Mode:Managed Access Point: Not-Associated Tx-Power=20 dBm Retry short limit:7 RTS thr:off Fragment thr:off Power Management:off Can you please help me? You can send here output from dmesg or/and syslog.
balbes150 Posted August 3, 2018 Author Posted August 3, 2018 1 hour ago, Reddwarf said: There is no external connection point, but I remember reading that you can solder on a cable on the board if you remove the lid from the box. Do you know anything about that? If not I have to investigate further, but I know it is possible at least with the Mini M8S.  Many TV boxes on the Board have contacts for UART connection to which you can solder the wires to connect the USB-UART Converter.. You need to look at the surface of the Board or search the Internet ready description.
Reddwarf Posted August 3, 2018 Posted August 3, 2018 4 minutes ago, balbes150 said: Many TV boxes on the Board have contacts for UART connection to which you can solder the wires to connect the USB-UART Converter.. You need to look at the surface of the Board or search the Internet ready description. Will do Is there a good windows program to capture the output that I can download and use? I will connest toe UART outut to a RS232 -> USB converter onnected to a PC...
TheMojoMan Posted August 3, 2018 Posted August 3, 2018 1 hour ago, pisach said: You can send here output from dmesg or/and syslog. Hello pisach, thank you so much for your help! I saw there are a ton of errors regarding SV6XXX in dmesg ... dmesg.txt syslog.txt
