jernej Posted March 6, 2019 Posted March 6, 2019 4 minutes ago, @lex said: Err... Just don't know how to do that... In a proper way I mean. There is a ton of Google hits on this topic, but in short what I do: 1. Pull latest linux-next (updated every work day) and create new branch from it 2. Make small, incremental commits (meaning of a "small, incremental commit" is often a gray area) 3. Test changes 4. Run git format-patch on them and add a cover letter if there is more than one patch 5. Check patch(es) with "scripts/checkpatch.pl <patches>" and fix reported warnings/errors ("line over 80 characters" warning can be ignored for DT patches) 6. Send patch(es) with optional cover letter with "git send-email" to maintainers and mailing lists. E-mail addresses are provided by "scripts/get_maintainer.pl <patches>" Be prepared that first revision of patches won't be accepted as-is. My average is 3-4 revisions, but simple DT patches are often merged directly or need only small revision. Please search for tutorial as I skipped few details, like how commit message should look like. It might look hard now, but after two or so contributions you'll be well aware what to do next time. You'll be able to submit simple DT patches in 10 min after you tested them. If you are unsure, you can still send patches to me first and I'll tell you what to fix before sending them to maintainers and mailing lists.
@lex Posted March 6, 2019 Posted March 6, 2019 Okay, I promise i will try to learn that. Anyway, Your dma code seems to work for the SPI0 although the device is not connected yet and need some tests. [ 3.983705] fbtft: module is from the staging directory, the quality is unknown, you have been warned. [ 3.990224] fb_ili9341: module is from the staging directory, the quality is unknown, you have been warned. [ 3.990921] fbtft_of_value: buswidth = 8 [ 3.990929] fbtft_of_value: debug = 0 [ 3.990932] fbtft_of_value: rotate = 90 [ 3.990934] fbtft_of_value: fps = 60 [ 3.990936] fbtft_of_value: txbuflen = 16384 [ 4.273841] graphics fb0: fb_ili9341 frame buffer, 320x240, 150 KiB video memory, 16 KiB buffer memory, fps=62, spi0.0 at 50 MHz [ 4.276796] sun4i-drm display-engine: fb1: DRM emulated frame buffer device
dreddit Posted March 7, 2019 Posted March 7, 2019 Hello Anybody developing this release, I've found in the Orangepi 3 4.9 kernel, a fix for the reboot issue and it works on their Ubuntu 16.04 release, the script/config is here https://github.com/orangepi-xunlong/OrangePiH6_external/blob/master/sys_config/OrangePiH6_3_sys_config.fex In addition seems to fix USB 3.0 speed issue, but only sees two cores in the ubuntu 16.04 release, early days I guess. I'll keep digging.
constantius Posted March 7, 2019 Author Posted March 7, 2019 https://github.com/krachlatte/armbian-orangepi3/releases/download/v0.11/v0.11_Armbian_5.76_Orangepi3_Ubuntu_bionic_dev_4.20.12.img.bz2 Not boot at all on orangepi 3. I thought maybe i can login on putty but not.....
jernej Posted March 7, 2019 Posted March 7, 2019 17 hours ago, @lex said: Anyway, Your dma code seems to work for the SPI0 although the device is not connected yet and need some tests. Please let me know if it works for you. I plan to send DMA patches today.
FrancescoT Posted March 7, 2019 Posted March 7, 2019 10 hours ago, constantius said: https://github.com/krachlatte/armbian-orangepi3/releases/download/v0.11/v0.11_Armbian_5.76_Orangepi3_Ubuntu_bionic_dev_4.20.12.img.bz2 Not boot at all on orangepi 3. I thought maybe i can login on putty but not..... Do you have the OPi3 with eMMC?
martinayotte Posted March 7, 2019 Posted March 7, 2019 1 hour ago, FrancescoT said: Do you have the OPi3 with eMMC? Yes ! ... And I've just did a successful "nand-sata-install" ... @krachlatte do you plan to send a PR for your recent work on OPi3 ? I would like to work on the WiFi to see if I can get it working ? BTW, from which other board did you use as a template to start this OPi3 ? EDIT : I got WiFi working by decompiling/edit/recompiling your existing DTB ...
@lex Posted March 7, 2019 Posted March 7, 2019 5 hours ago, jernej said: Please let me know if it works for you. I plan to send DMA patches today. Sure, but sorry, no progress yet to test your code, I got stuck with the error below and i could not figure out where the mistake is. The message is obvious, but the same setup works with others sbc with 4.18, 4.19 and 4.20. [ 3.455164] sun50i-h6-pinctrl 300b000.pinctrl: pin PC5 already requested by 5010000.spi; cannot claim for 300b000.pinctrl:69 [ 3.444948] fbtft: module is from the staging directory, the quality is unknown, you have been warned. [ 3.454515] fb_ili9341: module is from the staging directory, the quality is unknown, you have been warned. [ 3.454940] fbtft_of_value: buswidth = 8 [ 3.454947] fbtft_of_value: debug = 0 [ 3.454950] fbtft_of_value: rotate = 90 [ 3.454953] fbtft_of_value: fps = 60 [ 3.454955] fbtft_of_value: txbuflen = 16384 [ 3.476347] fb_ili9341 spi0.0: gpio_request_one('cs-gpios'=69) failed with -22 [ 3.483740] fb_ili9341: probe of spi0.0 failed with error -22 [ 4.091824] sun4i-drm display-engine: fb0: DRM emulated frame buffer device dma: dma-controller@3002000 { compatible = "allwinner,sun50i-h6-dma"; reg = <0x03002000 0x1000>; interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_BUS_DMA>, <&ccu CLK_MBUS_DMA>; clock-names = "bus", "mbus"; dma-channels = <16>; dma-requests = <46>; resets = <&ccu RST_BUS_DMA>; #dma-cells = <1>; }; pio: pinctrl@300b000 { . . spi0_pins: spi0 { pins = "PC0", "PC2", "PC3", "PC5"; function = "spi0"; }; }; spi0: spi@5010000 { compatible = "allwinner,sun8i-h3-spi"; reg = <0x05010000 0x1000>; interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_BUS_SPI0>, <&ccu CLK_SPI0>; clock-names = "ahb", "mod"; dmas = <&dma 23>, <&dma 23>; dma-names = "rx", "tx"; pinctrl-names = "default"; pinctrl-0 = <&spi0_pins>; resets = <&ccu RST_BUS_SPI0>; status = "disabled"; num-cs = <1>; #address-cells = <1>; #size-cells = <0>; }; &pio { spi0_cs_pins: spi0_cs_pins { pins = "PC5", "PH3"; function = "gpio_out"; }; }; &spi0 { #address-cells = <1>; #size-cells = <0>; status = "okay"; pinctrl-0 = <&spi0_pins &spi0_cs_pins>; cs-gpios = <&pio 2 5 GPIO_ACTIVE_HIGH>, <&pio 7 3 GPIO_ACTIVE_HIGH>; num-cs = <2>; pitft: pitft@0{ compatible = "ilitek,ili9341"; reg = <0>; status = "okay"; spi-max-frequency = <50000000>; rotate = <90>; fps = <60>; bgr = <1>; buswidth = <8>; txbuflen = <16384>; dc-gpios = <&pio 2 9 GPIO_ACTIVE_HIGH>; /* PC9 */ reset-gpios = <&pio 2 8 GPIO_ACTIVE_HIGH>; /* PC8 */ led-gpios = <&pio 2 7 GPIO_ACTIVE_LOW>; /* PC7 */ cs-gpios = <&pio 2 5 GPIO_ACTIVE_HIGH>; /* PC5 */ <== kernel complain debug = <0x0>; }; };
jernej Posted March 7, 2019 Posted March 7, 2019 10 minutes ago, @lex said: I got stuck with the error below and i could not figure out where the mistake is. DMA channels for SPI0 are 22 and 22 (Rx, Tx). BTW, I already sent patches, but I still want to know if it will work for you once you fix DT issues. 1
jernej Posted March 7, 2019 Posted March 7, 2019 @@lex Please be aware that H6 SPI has additional registers. Currently I can't say if they need to be set or not. If they has to be set, then SPI driver has to be extended with H6 support.
@lex Posted March 7, 2019 Posted March 7, 2019 2 minutes ago, jernej said: H6 SPI has additional registers. That seems to be the case here. Unfortunately, I have to wait for this support. Thanks anyway.
@lex Posted March 8, 2019 Posted March 8, 2019 @jernej FYI, i just did a simple test on /dev/spidev.0.0 with a loop, not sure what should be the result, but here it is: ./spidev_test -v -D /dev/spidev0.0 spi mode: 0x0 bits per word: 8 max speed: 500000 Hz (500 KHz) TX | FF FF FF FF FF FF 40 00 00 00 00 95 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F0 0D |......@.........................| RX | FF FF FF FF FF FF 40 00 00 00 00 95 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F0 0D |......@.........................|
martinayotte Posted March 8, 2019 Posted March 8, 2019 1 hour ago, @lex said: not sure what should be the result, but here it is If you mean that you did some SPI loopback wire test, this result is a bit strange since "spidev_test" should display the following : root@nanopct4:~# ./spidev_test spi mode: 0 bits per word: 8 max speed: 500000 Hz (500 KHz) FF FF FF FF FF FF 40 00 00 00 00 95 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF DE AD BE EF BA AD F0 0D
@lex Posted March 8, 2019 Posted March 8, 2019 9 hours ago, martinayotte said: If you mean that you did some SPI loopback wire test, this result is a bit strange since "spidev_test" Yes, I guess this is a confirmation SPI is not working yet. I used the -v to see some output (the spidev_test did not return anything). I had some hope that TX would be the data sent and RX would be the receiving data which is the same.
martinayotte Posted March 8, 2019 Posted March 8, 2019 54 minutes ago, @lex said: I had some hope that TX would be the data sent and RX would be the receiving data which is the same. You've got some of the bytes (first ones and few at the end), but missing the "DE AD BE EF BA AD" ones in the middle, so, maybe it is the DMA that didn't work properly ... EDIT, on my recently received OPi3, I've added manually SPI1 along SPIDEV in the Main DT, and I got it working propery : root@orangepi3:~# ./spidev_test spi mode: 0 bits per word: 8 max speed: 500000 Hz (500 KHz) FF FF FF FF FF FF 40 00 00 00 00 95 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF DE AD BE EF BA AD F0 0D
@lex Posted March 8, 2019 Posted March 8, 2019 (edited) 32 minutes ago, martinayotte said: I've added manually SPI1 along SPIDEV in the Main DT, Can you share your DT changes? Did you use the new dma? O used this code: https://github.com/torvalds/linux/blob/master/tools/spi/spidev_test.c Edited March 8, 2019 by @lex spidev_test
@lex Posted March 8, 2019 Posted March 8, 2019 (edited) Using this code i got an output but similar to the previous one. https://github.com/rm-hull/spidev-test ./spidev_test -D /dev/spidev0.0 spi mode: 0x0 bits per word: 8 max speed: 500000 Hz (500 KHz) RX | FF FF FF FF FF FF 40 00 00 00 00 95 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F0 0D | ......@....�..................�. PS: the TX data: uint8_t default_tx[] = { 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x40, 0x00, 0x00, 0x00, 0x00, 0x95, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xF0, 0x0D, }; Edited March 8, 2019 by @lex TX data
martinayotte Posted March 8, 2019 Posted March 8, 2019 2 hours ago, @lex said: Using this code i got an output but similar to the previous one. Oh ! You're right ! The "DE AD BE EF BA AD" has been removed even in Torvald's tree ... https://github.com/torvalds/linux/blob/master/tools/spi/spidev_test.c Probably for political/ethical reasons since "Dead Beef Bad Food" was there years ago, and only "Food" is still present ... It will be difficult to create new Vegetarian phrase in HEX ... EDIT : I've found almost a vegetarian one : CAFEF00D ... https://en.wikipedia.org/wiki/Hexspeak EDIT2 : Just for fun, I tried to find when it has been removed, probably between 3.10.y and 4.0.y, but I didn't found the commit itself ... https://raw.githubusercontent.com/raspberrypi/linux/rpi-3.10.y/Documentation/spi/spidev_test.c EDIT3: I found the commit in March 2015 : https://github.com/torvalds/linux/commit/30061915be6e3a2c2a4bc4f22a229d4eb7b7cc65#diff-cb4325e22952faf785e23bc6978e90ae
ImmortanJoe Posted March 9, 2019 Posted March 9, 2019 Is it within the scope of Armbian to attempt support for the MiniPCIe port with the mainline kernel? I didn't give it much thought until I remembered hat there are MiniPCIe to SATA adapters. My bandwidth and time are too low to have been much use for the early stages sorry. Someone else had always tried the newest iteration before I'd finished downloading it.
lanefu Posted March 9, 2019 Posted March 9, 2019 13 minutes ago, ImmortanJoe said: Is it within the scope of Armbian to attempt support for the MiniPCIe port with the mainline kernel? I didn't give it much thought until I remembered hat there are MiniPCIe to SATA adapters. My bandwidth and time are too low to have been much use for the early stages sorry. Someone else had always tried the newest iteration before I'd finished downloading it. Not for Opi3... defective by design.. http://linux-sunxi.org/H6#Errata Check out espressobin if you need SATA and MiniPCIe
ImmortanJoe Posted March 9, 2019 Posted March 9, 2019 5 hours ago, lanefu said: Not for Opi3... defective by design.. http://linux-sunxi.org/H6#Errata So that's what is wrong with it. Strange implementation coupled with difficulties doing some things with the Linux framework. Am I reading it correctly that the PCIe controller has either a banked interface or a potentially rolling window? Hm. Besides odd setup, DMA transactions would still function normally, right?
hojnikb Posted March 9, 2019 Posted March 9, 2019 Devices with modified drivers should work, so it's not like its totally useless.
martinayotte Posted March 9, 2019 Posted March 9, 2019 Armbian has now the new OrangePi3 WIP ! WiFi and eMMC tested ... 4
Werner Posted March 10, 2019 Posted March 10, 2019 If you hardly need it you have to build it on your own. May take a while until it is listed.
alex.scott.961 Posted March 10, 2019 Posted March 10, 2019 12 hours ago, martinayotte said: Armbian has now the new OrangePi3 WIP ! WiFi and eMMC tested ... Thank you!! Just for my understanding / curiosity... is the reason the OPi3 is built using an older U-Boot version because of the HDMI issue mentioned earlier? And once we move to Kernel 5.x this should be resolved? I only ask because I'm eager for Kernel 5 for video acceleration!
martinayotte Posted March 10, 2019 Posted March 10, 2019 1 hour ago, alex.scott.961 said: is the reason the OPi3 is built using an older U-Boot version Current DEV is using U-Boot v2018.11 and Kernel 4.20.12, so this is no so old ... 1 hour ago, alex.scott.961 said: once we move to Kernel 5.x this should be resolved 5.0.y is in our plans, but it will take awhile since it is a tedious jobs of cleaning the useless patches without doing that blindly ...
jernej Posted March 10, 2019 Posted March 10, 2019 20 minutes ago, martinayotte said: Current DEV is using U-Boot v2018.11 and Kernel 4.20.12, so this is no so old ... That's true, but there were some H6 DRAM improvements in 2019.01 IIRC. EDIT: I probably mixed up with 3GB memory support (previously was only possible to setup 2 or 4 GB, not 3).
martinayotte Posted March 10, 2019 Posted March 10, 2019 12 minutes ago, jernej said: That's true, but there were some H6 DRAM improvements in 2019.01 IIRC. Ok ! Since switching U-Boot is a less painful task than kernel itself, maybe we can switch sooner ! I will try this afternoon ... 1
krachlatte Posted March 10, 2019 Posted March 10, 2019 hi guys, i just build the image, so you could give it a try... https://github.com/krachlatte/armbian-orangepi3/releases/tag/v0.12 i still did not receive the hardware many thanks so far
