martinayotte Posted May 16, 2019 Posted May 16, 2019 13 minutes ago, Flole said: Nope, it clearly says Orange_PI-3 on it, downloaded from the Google Drive. Dated at November 26th 2018. So, it should be the same as mine : Ok ! The block diagram is wrong, but I never care about block diagram, I care only about real schematic ... Page 8 clearly states that VCC-5V is direct from DC-IN !
NicoD Posted May 16, 2019 Posted May 16, 2019 2 hours ago, Flole said: t's indeed a little low on mine aswell Hi. I've only had that powering with barrel jack. With microUSB it's as stable as could be. It's the world in reverse. I expected the cables from OPi to not be good enough. I've got 2 and both are like that. I don't know. I havent tried with a PSU with barrel jack. Don't know if I've got one. I've showed this behaviour in my review video : https://www.youtube.com/watch?v=D2SIpXTOb9A&t=492s 1
Flole Posted May 16, 2019 Posted May 16, 2019 30 minutes ago, martinayotte said: So, it should be the same as mine : Ok ! The block diagram is wrong, but I never care about block diagram, I care only about real schematic ... Page 8 clearly states that VCC-5V is direct from DC-IN ! Not only the block diagram is wrong but the Power Tree aswell (which is somewhat important). And Page 10 clearly says that the VCC-5V is connected to the GND Pin of the USB, which is also not correct..... I don't really trust these schematics anymore.... 18 minutes ago, NicoD said: With microUSB it's as stable as could be. It's the world in reverse. Just tried this aswell, and indeed it's a lot better. Weird..... Anyways, there doesn't seem to be some kind of regulator involved so it's all good now!
martinayotte Posted May 16, 2019 Posted May 16, 2019 1 hour ago, Flole said: And Page 10 clearly says that the VCC-5V is connected to the GND Pin of the USB I think it is the labels of the connector that are swapped : VBUS is VCC on pin 4, and GND would be pin 1 ...
Flole Posted May 16, 2019 Posted May 16, 2019 GND is actually pin 4 of a USB connector. The numbering is also not reversed cause then D+ and D- wouldn't be correct anymore. So that's just wrong in the schematics.
GeorgeP Posted May 17, 2019 Posted May 17, 2019 With my OPi3 powered from the 'genuine' power adaptor via the power jack I'm not seeing any voltage issues. On no load I see 5.2v at the USB sockets..
NicoD Posted May 17, 2019 Posted May 17, 2019 5 hours ago, GeorgeP said: With my OPi3 powered from the 'genuine' power adaptor via the power jack I'm not seeing any voltage issues. On no load I see 5.2v at the USB sockets.. That sais enough. They are overvolting their PSU's so it would not undervolt too quickly. I'm using a 4A 5V PSU that's 5.1V and I've got undervoltage. And it's not no load voltage that's important. It's full load voltage. But because doing it wrong you've proven they know about it.
NicoD Posted May 17, 2019 Posted May 17, 2019 Now the question is, what's causing the resistance on the barrel jack line? It's not there on microUSB.
greg798 Posted May 23, 2019 Posted May 23, 2019 Hi Someone opi3 repair bootrom? Flash zidoo firmaware to opi3 and after have problem. Thanks
larrylart Posted May 25, 2019 Posted May 25, 2019 I trying to get the USB3 working with orange pi lite 2 and the latest nigtly snapshot 5.1.3-sunxi64 #5.87.190522. I notice that the usb3 is disabled in the the dtb file: dwc3@5200000 { compatible = "snps,dwc3"; reg = <0x5200000 0x10000>; interrupts = <0x0 0x1a 0x4>; clocks = <0x2 0x72 0x2 0x72 0xa 0x0>; clock-names = "ref", "bus_early", "suspend"; resets = <0x2 0x33>; dr_mode = "host"; phys = <0x1f>; phy-names = "usb3-phy"; status = " disabled "; phandle = <0x52>; }; phy@5210000 { compatible = "allwinner,sun50i-h6-usb3-phy"; reg = <0x5210000 0x10000>; clocks = <0x2 0x6a>; resets = <0x2 0x2d>; #phy-cells = <0x0>; status = "disabled"; phandle = <0x1f>; }; I changed the status (from disable to okay) on both and recompile the dts file, and now I can see the usb3 HUB: lsusb -t /: Bus 07.Port 1: Dev 1, Class=root_hub, Driver=musb-hdrc/1p, 480M /: Bus 06.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M /: Bus 05.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M /: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M /: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M /: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M /: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M However no devices are detected, no even powering when plugged into the USB port. I contacted Icenowy, who currently maintains the usb3 driver, and have been advised that current driver should be working. I wonder if the issue rests in the dts file setup, current parameter setup, given the fact it was marked as disabled? I noticed someone in the H6 dev forum mentioned that this was working back a month or so ago, however it does not seem to be working in the latest sanpshot.
dolphs Posted May 28, 2019 Posted May 28, 2019 hello I've been gone from the game for a while, just flashed a new image ( 5.1.5 kernel for orangepioneplus ) and it seems it has been decided to downgrade CPU speed to 1,5GHz instead of 1.8GHz: "current policy: frequency should be within 480 MHz and 1.49 GHz. " ? Hopefully this can be set back to 1,8?
kexec Posted May 28, 2019 Posted May 28, 2019 14 hours ago, dolphs said: hello I've been gone from the game for a while, just flashed a new image ( 5.1.5 kernel for orangepioneplus ) and it seems it has been decided to downgrade CPU speed to 1,5GHz instead of 1.8GHz: "current policy: frequency should be within 480 MHz and 1.49 GHz. " ? Hopefully this can be set back to 1,8? i have just tried latest debian build kernel 5.1.3 and CPU show 1.8Ghz. HDMI works as it should, edid bug gone. you can now enjoy full HD resolution without any nasty magic i2c device is still not showing up my devices
may Posted May 30, 2019 Posted May 30, 2019 @larrylart use 5.0.3 dtb file with 5.1.5 kernel , at least the usb3 works in 2.0 mode I will investigate the difference between 5.0.3 and 5.1.5 of dts and dtsi file sun50i-h6-orangepi-lite2.dtb.5.0.13
AZ8 Posted May 30, 2019 Posted May 30, 2019 apt upgrade returned following Setting up linux-image-dev-sunxi64 (5.88.190529) ... Error! Your kernel headers for kernel 5.1.5-sunxi64 cannot be found. Please install the linux-headers-5.1.5-sunxi64 package, or use the --kernelsourcedir option to tell DKMS where it's located Unfortunately, there is no linux-headers-5.1.5-sunxi64 package
may Posted May 31, 2019 Posted May 31, 2019 for orangepi lite2 users: the original dts file misses definition of "reg_usb_vbus", the usb3.0 port has no power. this dtb file should works sun50i-h6-orangepi-lite2.dtb.fixed2
data Posted May 31, 2019 Posted May 31, 2019 Great, thank you! Once I've tried it, I'll report back here.
maxlinux2000 Posted May 31, 2019 Posted May 31, 2019 U-Boot 2019.04-armbian (May 31 2019 - 01:42:20 +0200) Allwinner Technology CPU: Allwinner H6 (SUN50I) Model: OrangePi 3 DRAM: 2 GiB MMC: mmc@4020000: 0, mmc@4022000: 1 Loading Environment from EXT4... ** File not found /boot/boot.env ** ** Unable to read "/boot/boot.env" from mmc0:1 ** In: serial@5000000 Out: serial@5000000 Err: serial@5000000 Net: No ethernet found. starting USB... No controllers found Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3042 bytes read in 1 ms (2.9 MiB/s) ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from mmc 165 bytes read in 2 ms (80.1 KiB/s) 27608 bytes read in 8 ms (3.3 MiB/s) 4161 bytes read in 4 ms (1015.6 KiB/s) Applying kernel provided DT fixup script (sun50i-h6-fixup.scr) ## Executing script at 44000000 5587948 bytes read in 567 ms (9.4 MiB/s) 14563336 bytes read in 1473 ms (9.4 MiB/s) ## Loading init Ramdisk from Legacy Image at 4fe00000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 5587884 Bytes = 5.3 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 4fa00000 Booting using the fdt blob at 0x4fa00000 Loading Ramdisk to 49aab000, end 49fff3ac ... OK Loading Device Tree to 0000000049a3b000, end 0000000049aaafff ... OK Starting kernel ... Debian GNU/Linux 9 orangepi3 ttyS0 orangepi3 login: [ 82.424484] Internal error: SP/PC alignment exception: 8a00P [ 82.424489] Modules linked in: zstd zram btsdio bluetooth snd_soc_hdmi_codecx [ 82.463741] Process swapper/2 (pid: 0, stack limit = 0x0000000044a1bf13) [ 82.473532] CPU: 2 PID: 0 Comm: swapper/2 Not tainted 5.1.5-sunxi64 #5.88.191 [ 82.484073] Hardware name: OrangePi 3 (DT) [ 82.491347] pstate: 00000085 (nzcv daIf -PAN -UAO) [ 82.499353] pc : 0xf [ 82.504745] lr : bsearch+0x50/0xb8 [ 82.511367] sp : ffff000010013c80 [ 82.517858] x29: ffff000010013c80 x28: 0000000000000010 [ 82.526337] x27: 0000000000000000 x26: ffff800074c034a0 [ 82.534819] x25: ffff800074c034a0 x24: 000000000000000f [ 82.543312] x23: 0000000000000008 x22: 000000000000000f [ 82.551786] x21: 0000000000000001 x20: 0000000000000017 [ 82.560237] x19: 0000000000000001 x18: 0000000000000000 [ 82.568668] x17: ffff000010acba60 x16: ffff000010a88c58 [ 82.577098] x15: 0000000000000000 x14: ffff000010a88c58 [ 82.585533] x13: 0000000000000001 x12: ffff000010a88c30 [ 82.593964] x11: 0000000000000001 x10: ffffffffffffffff [ 82.602394] x9 : 0000000000000000 x8 : 0000000000000006 [ 82.610834] x7 : ffff800077bad870 x6 : 0000000000000040 [ 82.619232] x5 : ffff800073f30bc0 x4 : 000000000000000f [ 82.627577] x3 : 000000000000000f x2 : 0000000000000000 [ 82.635919] x1 : 0000000000000017 x0 : ffff800074c034a0 [ 82.644276] Call trace: [ 82.649759] 0xf [ 82.654611] resched_cpu+0xe4/0xe8 [ 82.661029] mod_timer+0x230/0x340 [ 82.667421] rwb_arm_timer+0x48/0x78 [ 82.673976] wb_timer_fn+0x154/0x178 [ 82.680515] blk_stat_timer_fn+0x154/0x168 [ 82.687565] call_timer_fn+0x20/0x78 [ 82.694114] expire_timers+0xc8/0xf8 [ 82.700609] run_timer_softirq+0xc4/0x200 [ 82.707501] __do_softirq+0x114/0x22c [ 82.714032] irq_exit+0xac/0xc0 [ 82.720039] __handle_domain_irq+0x60/0xb0 [ 82.727020] gic_handle_irq+0x58/0xa8 [ 82.733575] el1_irq+0xb8/0x140 [ 82.739577] arch_cpu_idle+0x10/0x18 [ 82.745991] do_idle+0x1f0/0x2d0 [ 82.752013] cpu_startup_entry+0x20/0x28 [ 82.758704] secondary_start_kernel+0x190/0x1d0 [ 82.766041] Code: bad PC value [ 82.771860] ---[ end trace 93be063b060c8efb ]--- [ 82.779230] Kernel panic - not syncing: Fatal exception in interrupt [ 82.788337] SMP: stopping secondary CPUs [ 82.794975] Kernel Offset: disabled [ 82.801130] CPU features: 0x002,20002004 [ 82.807715] Memory Limit: none [ 82.813392] Rebooting in 10 seconds.. kernbel panic in orangepi3 2GB RAM + Emmc, with last build: https://dl.armbian.com/orangepi3/nightly/Armbian_5.88.190601_Orangepi3_Debian_stretch_dev_5.1.5.7z
data Posted June 1, 2019 Posted June 1, 2019 Orange Pi Lite2 affected as well: After upgrading to the latest nightly (Jun-01), it does not boot anymore :(
dziobak Posted June 2, 2019 Posted June 2, 2019 Ubuntu Bionic, latest kernels (5.1.6 and 5.1.7) from dev packages 190602+ not boot. Boot stopped after "[ OK ] Started udev Kernel Device Manager." silently or shows "Unable to handle kernel paging request ..." I went back to 190601 (latest 5.1.5).
Igor Posted June 8, 2019 Posted June 8, 2019 It boots (at least for me) after this https://github.com/armbian/build/pull/1407
GeorgeP Posted June 8, 2019 Posted June 8, 2019 Seeing the current issues I'm happy that I'm running an earlier build :-) Welcome to ARMBIAN 5.83 user-built Debian GNU/Linux 10 (buster) 5.0.9-sunxi64 System load: 2.14 2.11 2.06 Up time: 23 days Memory usage: 60 % of 1997MB Zram usage: 1 % of 998Mb IP: 192.168.0.5 CPU temp: 56°C Usage of /: 27% of 7.1G Currently running PiHole, MQTT and SETI@Home :-D
greg798 Posted June 8, 2019 Posted June 8, 2019 Hi. Not booting last armbian ubuntu. Opi 3 flash sd on 190607 and freeze boot console massages key map. solder the capacitor? maybe two capacitor?
Igor Posted June 8, 2019 Posted June 8, 2019 8 minutes ago, greg798 said: Opi 3 flash sd on 190607 and freeze boot console massages key map. Use images from here https://www.armbian.com/orange-pi-3/ nightly images will be ok from tomorrows builds. 2
data Posted June 8, 2019 Posted June 8, 2019 @Igor Thank you very much for your efforts! Will this be incorporated in the Lite2 image as well from tormorrow?
Igor Posted June 8, 2019 Posted June 8, 2019 2 minutes ago, data said: @Igor Thank you very much for your efforts! Will this be incorporated in the Lite2 image as well from tormorrow? All H6 boards. 1
dolphs Posted June 9, 2019 Posted June 9, 2019 apt-get update & apt-get -y upgrade from 587 -> 5.88 no go on Orange Pi One+. As well fresh 5.88 flash ( built manually just few minutes ago ), Armbian_5.88_Orangepioneplus_Debian_stretch_dev_5.1.7 - NOK ... BTW 5.1.8 just arrived, as well 4.19.49 is latest while 47 is being used, worth bumping both? Unfortuantely " Armbian_5.88_Orangepioneplus_Debian_stretch_next_4.19.47 " - NOK
data Posted June 9, 2019 Posted June 9, 2019 Probably you have to wait a little bit longer. The latest nightly is still from the 7th/8th at this moment...
dolphs Posted June 10, 2019 Posted June 10, 2019 hmm still no newer builds (7/8) as it seems: https://dl.armbian.com/orangepioneplus/ OR https://dl.armbian.com/orangepi3/ - let's wait some more then ...
Werner Posted June 10, 2019 Posted June 10, 2019 You can build your own image using the the build script available here: https://github.com/armbian/build
Igor Posted June 10, 2019 Posted June 10, 2019 8 minutes ago, dolphs said: hmm still no newer builds (7/8) as it seems Or https://forum.armbian.com/topic/9368-orangepi-3-h6-allwiner-chip/?do=findComment&comment=80443 Sometimes rebuild stuck.
