I attempted to file a bug using `reportbug`, but since the kernel package is from Armbian and the report went to Debian, I assume that is a dead end. https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=1137721 I will mostly copy/paste from that report, here, but I also ran `armbianmonitor -u`. https://paste.armbian.com/wenegucita I run a home backup server with a 1TB SSD attached to an ODroid HC1 board. There is no redundancy, but I do keep a limited history of snapshots, taken hourly and trimmed down to a small number of hourly, daily, weekly, monthly, and yearly snapshots. There should be at most about 20 snapshots existing at a time. I have a daily cron job to run a balance operation. The mount point is `/backup` . Relevant line from /etc/fstab: /dev/mapper/backup /backup btrfs noatime,noauto,nodev,nosuid,noexec,compress=zlib:9 0 0 Command used for daily balance: btrfs balance start --full-balance '/backup' The filesystem only seems to be about half full: ansible@backup:~ $ sudo btrfs filesystem df --si /backup Data, single: total=430.57GB, used=428.24GB System, DUP: total=67.11MB, used=81.92kB Metadata, DUP: total=3.22GB, used=2.48GB GlobalReserve, single: total=536.87MB, used=49.15kB ansible@backup:~ $ My best understanding is that the messages that follow indicate that something is attempting to address space beyond 16TB, and that seems like a bug because my disk is only 1TB total. I would appreciate anyone with a firmer grasp of the topic at least confirming whether that is an accurate reading of the warnings and errors. If not, I might suggest that the warnings and errors could be improved, but I am open to correction if I just failed to understand what they are telling me. The problem seems to be triggered by any attempt to rebalance metadata or system data with a usage limit of 1 or higher. Excerpt from a command session: ansible@backup:~ $ time sudo btrfs balance start -musage=1 /backup; echo $? ERROR: error during balancing '/backup': Read-only file system There may be more info in syslog - try dmesg | tail real 0m0.304s user 0m0.040s sys 0m0.082s 1 ansible@backup:~ $ sudo umount /backup && sudo mount -o skip_balance /backup && sudo btrfs balance cancel /backup ansible@backup:~ $ time sudo btrfs balance start -f -susage=1 /backup; echo $? ERROR: error during balancing '/backup': Read-only file system There may be more info in syslog - try dmesg | tail real 0m0.321s user 0m0.023s sys 0m0.096s 1 ansible@backup:~ $ Excerpt from dmesg from that time: [114023.693265] BTRFS info (device dm-0): balance: start -musage=1 -susage=1 [114023.695656] BTRFS error (device dm-0): extent buffer 18905857064960 is beyond 32bit page cache limit [114023.695669] BTRFS error (device dm-0): reached 32bit limit for logical addresses [114023.695677] BTRFS error (device dm-0): due to page cache limit on 32bit systems, metadata beyond 16T can't be accessed [114023.695686] BTRFS error (device dm-0): please consider upgrading to 64bit kernel/hardware [114023.695699] ------------[ cut here ]------------ [114023.695706] WARNING: CPU: 4 PID: 30371 at fs/btrfs/space-info.h:208 btrfs_space_info_update_bytes_may_use+0x9c/0x1c0 [btrfs] [114023.695813] Modules linked in: aes_arm_bs crypto_simd dm_crypt cpufreq_conservative cpufreq_userspace cpufreq_powersave sunrpc zram zsmalloc binfmt_misc evdev sg nfnetlink ip_tables x_tables ipv6 autofs4 btrfs blake2b_generic xor xor_neon raid6_pq li bcrc32c sd_mod t10_pi crc64_rocksoft uas usb_storage scsi_mod scsi_common gpio_keys [114023.695959] CPU: 4 PID: 30371 Comm: btrfs Tainted: G W 6.6.122-current-odroidxu4 #1 [114023.695969] Hardware name: Samsung Exynos (Flattened Device Tree) [114023.695980] unwind_backtrace from show_stack+0x10/0x14 [114023.696000] show_stack from dump_stack_lvl+0x40/0x4c [114023.696014] dump_stack_lvl from __warn+0x78/0x154 [114023.696025] __warn from warn_slowpath_fmt+0x1b4/0x1bc [114023.696035] warn_slowpath_fmt from btrfs_space_info_update_bytes_may_use+0x9c/0x1c0 [btrfs] [114023.696127] btrfs_space_info_update_bytes_may_use [btrfs] from btrfs_block_rsv_release+0x1f4/0x2f4 [btrfs] [114023.696300] btrfs_block_rsv_release [btrfs] from btrfs_alloc_tree_block+0x118/0x6b4 [btrfs] [114023.696465] btrfs_alloc_tree_block [btrfs] from btrfs_force_cow_block+0x148/0xa60 [btrfs] [114023.696628] btrfs_force_cow_block [btrfs] from btrfs_cow_block+0xe4/0x2bc [btrfs] [114023.696792] btrfs_cow_block [btrfs] from btrfs_search_slot+0x6dc/0xc08 [btrfs] [114023.696957] btrfs_search_slot [btrfs] from btrfs_update_device+0xa4/0x248 [btrfs] [114023.697122] btrfs_update_device [btrfs] from btrfs_chunk_alloc_add_chunk_item+0xcc/0x638 [btrfs] [114023.697287] btrfs_chunk_alloc_add_chunk_item [btrfs] from reserve_chunk_space+0xec/0x180 [btrfs] [114023.697451] reserve_chunk_space [btrfs] from check_system_chunk+0x6c/0x74 [btrfs] [114023.697615] check_system_chunk [btrfs] from btrfs_inc_block_group_ro+0x228/0x234 [btrfs] [114023.697780] btrfs_inc_block_group_ro [btrfs] from btrfs_relocate_block_group+0x94/0x48c [btrfs] [114023.697945] btrfs_relocate_block_group [btrfs] from btrfs_relocate_chunk+0x3c/0x180 [btrfs] [114023.698108] btrfs_relocate_chunk [btrfs] from btrfs_balance+0x864/0x13b8 [btrfs] [114023.698272] btrfs_balance [btrfs] from btrfs_ioctl+0x248c/0x28c4 [btrfs] [114023.698436] btrfs_ioctl [btrfs] from sys_ioctl+0x288/0xc60 [114023.698533] sys_ioctl from ret_fast_syscall+0x0/0x54 [114023.698547] Exception stack(0xf2575fa8 to 0xf2575ff0) [114023.698556] 5fa0: 00000000 00000003 00000003 c4009420 bebe7fd0 bebe7f70 [114023.698565] 5fc0: 00000000 00000003 bebe7fd0 00000036 005bfb78 bebe86f4 00000001 0058b190 [114023.698572] 5fe0: 00000036 bebe7f58 b6d718b1 b6cdf736 [114023.698580] ---[ end trace 0000000000000000 ]--- [114023.698802] BTRFS error (device dm-0): extent buffer 18905857064960 is beyond 32bit page cache limit [114023.698821] ------------[ cut here ]------------ [114023.698827] WARNING: CPU: 4 PID: 30371 at fs/btrfs/block-group.c:2783 btrfs_create_pending_block_groups+0x674/0x67c [btrfs] [114023.698925] BTRFS: Transaction aborted (error -75) [114064.918054] Modules linked in: aes_arm_bs crypto_simd dm_crypt cpufreq_conservative cpufreq_userspace cpufreq_powersave sunrpc zram zsmalloc binfmt_misc evdev sg nfnetlink ip_tables x_tables ipv6 autofs4 btrfs blake2b_generic xor xor_neon raid6_pq libcrc32c sd_mod t10_pi crc64_rocksoft uas usb_storage scsi_mod scsi_common gpio_keys [114064.918234] CPU: 5 PID: 30410 Comm: btrfs Tainted: G W 6.6.122-current-odroidxu4 #1 [114064.918245] Hardware name: Samsung Exynos (Flattened Device Tree) [114064.918256] unwind_backtrace from show_stack+0x10/0x14 [114064.918272] show_stack from dump_stack_lvl+0x40/0x4c [114064.918284] dump_stack_lvl from __warn+0x78/0x154 [114064.918296] __warn from warn_slowpath_fmt+0x130/0x1bc [114064.918307] warn_slowpath_fmt from btrfs_create_pending_block_groups+0x674/0x67c [btrfs] [114064.918399] btrfs_create_pending_block_groups [btrfs] from __btrfs_end_transaction+0x38/0x2a0 [btrfs] [114064.918567] __btrfs_end_transaction [btrfs] from btrfs_inc_block_group_ro+0x1f0/0x234 [btrfs] [114064.918733] btrfs_inc_block_group_ro [btrfs] from btrfs_relocate_block_group+0x94/0x48c [btrfs] [114064.918899] btrfs_relocate_block_group [btrfs] from btrfs_relocate_chunk+0x3c/0x180 [btrfs] [114064.919065] btrfs_relocate_chunk [btrfs] from btrfs_balance+0x864/0x13b8 [btrfs] [114064.919231] btrfs_balance [btrfs] from btrfs_ioctl+0x248c/0x28c4 [btrfs] [114064.919397] btrfs_ioctl [btrfs] from sys_ioctl+0x288/0xc60 [114064.919491] sys_ioctl from ret_fast_syscall+0x0/0x54 [114064.919505] Exception stack(0xf26b9fa8 to 0xf26b9ff0) [114064.919516] 9fa0: 00000000 00000003 00000003 c4009420 beae9fc0 beae9f60 [114064.919527] 9fc0: 00000000 00000003 beae9fc0 00000036 0057fb78 beaea6f1 00000001 0054b190 [114064.919537] 9fe0: 00000036 beae9f48 b6d118b1 b6c7f736 [114064.919614] ---[ end trace 0000000000000000 ]--- [114064.919632] BTRFS: error (device dm-0: state A) in btrfs_create_pending_block_groups:2783: errno=-75 unknown [114064.919647] BTRFS info (device dm-0: state EA): forced readonly [114064.920025] ------------[ cut here ]------------ [114064.920039] WARNING: CPU: 5 PID: 30410 at fs/btrfs/space-info.h:208 btrfs_space_info_update_bytes_may_use+0x9c/0x1c0 [btrfs] [114064.920182] Modules linked in: aes_arm_bs crypto_simd dm_crypt cpufreq_conservative cpufreq_userspace cpufreq_powersave sunrpc zram zsmalloc binfmt_misc evdev sg nfnetlink ip_tables x_tables ipv6 autofs4 btrfs blake2b_generic xor xor_neon raid6_pq libcrc32c sd_mod t10_pi crc64_rocksoft uas usb_storage scsi_mod scsi_common gpio_keys [114064.920385] CPU: 5 PID: 30410 Comm: btrfs Tainted: G W 6.6.122-current-odroidxu4 #1 [114064.920398] Hardware name: Samsung Exynos (Flattened Device Tree) [114064.920409] unwind_backtrace from show_stack+0x10/0x14 [114064.920426] show_stack from dump_stack_lvl+0x40/0x4c [114064.920441] dump_stack_lvl from __warn+0x78/0x154 [114064.920454] __warn from warn_slowpath_fmt+0x1b4/0x1bc [114064.920466] warn_slowpath_fmt from btrfs_space_info_update_bytes_may_use+0x9c/0x1c0 [btrfs] [114064.920559] btrfs_space_info_update_bytes_may_use [btrfs] from btrfs_block_rsv_release+0x1f4/0x2f4 [btrfs] [114064.920729] btrfs_block_rsv_release [btrfs] from btrfs_trans_release_chunk_metadata+0x2c/0x40 [btrfs] [114064.920900] btrfs_trans_release_chunk_metadata [btrfs] from __btrfs_end_transaction+0x38/0x2a0 [btrfs] [114064.921070] __btrfs_end_transaction [btrfs] from btrfs_inc_block_group_ro+0x1f0/0x234 [btrfs] [114064.921239] btrfs_inc_block_group_ro [btrfs] from btrfs_relocate_block_group+0x94/0x48c [btrfs] [114064.921406] btrfs_relocate_block_group [btrfs] from btrfs_relocate_chunk+0x3c/0x180 [btrfs] [114064.921572] btrfs_relocate_chunk [btrfs] from btrfs_balance+0x864/0x13b8 [btrfs] [114064.921741] btrfs_balance [btrfs] from btrfs_ioctl+0x248c/0x28c4 [btrfs] [114064.921913] btrfs_ioctl [btrfs] from sys_ioctl+0x288/0xc60 [114064.922009] sys_ioctl from ret_fast_syscall+0x0/0x54 [114064.922024] Exception stack(0xf26b9fa8 to 0xf26b9ff0) [114064.922036] 9fa0: 00000000 00000003 00000003 c4009420 beae9fc0 beae9f60 [114064.922046] 9fc0: 00000000 00000003 beae9fc0 00000036 0057fb78 beaea6f1 00000001 0054b190 [114064.922057] 9fe0: 00000036 beae9f48 b6d118b1 b6c7f736 [114064.922067] ---[ end trace 0000000000000000 ]--- [114064.922111] BTRFS info (device dm-0: state EA): balance: ended with status: -30 I tried balancing data, starting with low usage limits and moving up to no limit. That all went smoothly. The problem still occurred when trying to balance metadata, but the extent buffer number named in dmesg errors changed. I do not know whether that is significant or whether balancing data should be expected to be of any benefit in this situation. I did not keep full context from dmesg, but these are the commands issued: btrfs balance start -dusage=1 /backup btrfs balance start -dusage=10 /backup btrfs balance start -dusage=50 /backup btrfs balance start -dusage=75 /backup btrfs balance start -dusage=85 /backup btrfs balance start -dusage=95 /backup btrfs balance start -d /backup Most of those were pretty fast. The last one took several hours. I also checked my SSD for SMART errors, running a short self test and then a long one. No errors are reported. I do not know whether this is an architecture specific bug. It may be specific to 32 bit systems, or to ARM 32 bit, or it may not. I do not know whether this is an upstream bug, but it seems likely. The behavior in question seems to be related to the btrfs kernel component. The recommended fix is to attach the SSD to a 64 bit system to complete any operations requiring addresses that cannot be handled by the 32 bit system. I have not done that, yet, and I will hold off for a while, as it seems like that will only be a temporary fix. If I can gather any more relevant information while the system is still in this state, please let me know. -- System Information: Debian Release: 13.4 APT prefers stable-updates APT policy: (500, 'stable-updates'), (500, 'stable-security'), (500, 'stable') Architecture: armhf (armv7l) Kernel: Linux 6.6.122-current-odroidxu4 (SMP w/8 CPU threads; PREEMPT) Kernel taint flags: TAINT_WARN Locale: LANG=en_US.UTF-8, LC_CTYPE=en_US.UTF-8 (charmap=UTF-8) (ignored: LC_ALL set to en_US.UTF-8), LANGUAGE=en_US.UTF-8 Shell: /bin/sh linked to /usr/bin/dash Init: systemd (via /run/systemd/system) -- no debconf information
This week's work centers on board support expansion, kernel and U-Boot maintenance, and desktop and CI tooling refinements. On the platform side, the Radxa Cubie A5E received Wi-Fi enablement and a kernel refresh as part of a broader update, while the youyeetoo YY3588 was promoted from CSC to standard support and the YY3568 gained PCIe NVMe functionality. The NanoPi R76S and Rock 5 ITX were both migrated to mainline U-Boot v2026.04, dropping vendor-branch gates, and the Vanxoak HD-RK3506-EVB was added with vendor and board imagery. Kernel hygiene dominated the maintenance work: duplicate OPP labels on the Xiaoxin Pad Pro (sm8250) were corrected, broken UHS-I, xo-clock, SD, and DSI patches were removed from sm8550 trees for both 6.18 and 7.0, and a now-upstream r-spi backport was dropped from sunxi-6.18. The odroidxu4-current branch advanced to 6.6.141 across two successive bumps. Desktop and infrastructure tooling saw layered improvements through configng: alsa-ucm-conf and libcamera/v4l userspace were added to the minimal tier, PackageKit and AppStream landed at the mid tier, and DE postinst scripts now execute in the build chroot to resolve missing wallpaper. UEFI x86 and arm64 desktop spins were switched to GNOME on the edge kernel, and build infrastructure gained inline ShellCheck PR feedback, scoped token permissions, fork-aware artifact gating, and event-driven runner cleanup via systemd hooks. #Armbian #EmbeddedLinux #Rockchip #UBoot #KernelDevelopment ChangesAdd vendor and board image of Vanxoak HD-RK3506-EVB. by @SeeleVolleri in armbian/armbian.github.io#316Add wifi to Radxa Cubie A5E (kernel7.0). by @juanesf in armbian/build#9879ci: post ShellCheck findings and auto-fix suggestions inline on PRs. by @iav in armbian/build#9868ci: scope GITHUB_TOKEN writes to job-level in maintenance-lint-scripts-post. by @iav in armbian/build#9887ci: skip build-artifacts gating job on forks. by @iav in armbian/build#9865desktops: install alsa-ucm-conf at minimal tier. by @igorpecovnik in armbian/configng#923desktops: install libcamera/v4l userspace at minimal tier. by @igorpecovnik in armbian/configng#924desktops: run DE postinst scripts in build chroot (fix missing wallpaper). by @igorpecovnik in armbian/configng#927enh: substring filter for the board picker. by @iav in armbian/build#9843expose: switch uefi-x86 / uefi-arm64 to GNOME desktop on edge kernel. by @igorpecovnik in armbian/armbian.github.io#315feat(ccache-remote): parse password from DNS-SD TXT for redis backend. by @iav in armbian/build#9864feat(tools/shellfmt): accept positional file args for scoped format. by @iav in armbian/build#9863fix(runners): handle missing HOME in systemd hooks for runner-clean-pages. by @igorpecovnik in armbian/configng#928fix(sm8250): drop duplicate cpu7_opp21 label on Xiaoxin Pad Pro overclock OPP. by @igorpecovnik in armbian/build#9882fix(sm8550-6.18): drop broken sm8x50 UHS-I/xo-clock mbox patch. by @igorpecovnik in armbian/build#9884fix(sm8550-7.0): drop merged & broken SD/DSI patches. by @igorpecovnik in armbian/build#9885fix(sunxi-6.18): drop r-spi backport now merged in linux-6.18.y stable. by @igorpecovnik in armbian/build#9883gha: don't double-quote board/maintainer filter values. by @iav in armbian/os#462gnome: add packagekit + plugins + appstream at mid tier. by @igorpecovnik in armbian/configng#922module_cockpit: drop qemu-kvm (no riscv64 build; qemu-system covers it). by @igorpecovnik in armbian/configng#926nanopi-r76s: bump mainline u-boot to v2026.04 and drop vendor-branch gates. by @SuperKali in armbian/build#9869release-targets: flip UEFI desktop spins from current to edge. by @igorpecovnik in armbian/armbian.github.io#314rock-5-itx: link upstream kernel commit in pcie3 refclk u-boot patch. by @SuperKali in armbian/build#9861rock-5-itx: switch to mainline u-boot v2026.04. by @SuperKali in armbian/build#9848Rockchip: youyeetoo yy3568: enable pci-e NVMe ssd. by @hqnicolas in armbian/build#9877runner-cleanup: event-driven _diag/pages wipe via systemd hooks. by @igorpecovnik in armbian/configng#925Update for Radxa Cubie A5E. by @juanesf in armbian/build#9626Update odroidxu4-current to 6.6.140. by @belegdol in armbian/build#9867Update odroidxu4-current to 6.6.141. by @belegdol in armbian/build#9881Update radxa-cubie-a5e.csc with current kernel for build. by @juanesf in armbian/build#9874youyeetoo-yy3588: promote from CSC to standard support. by @SuperKali in armbian/build#9873View the full article
@Rodrigo Campos In my case the U-Boot side is not just a generic version choice. That baseline carries the board-specific path I tested: the zero2w-based defconfig, mmc0 broken-CD handling, H616 EMAC1/RMII support, I2C3 enablement, the LAN preinit step, and the extra EMAC-related clock/register writes. Since the kernel LAN attach depends on the board already being prepared by U-Boot, I preferred to keep the bootloader side conservative. So the short answer is: it is pinned because it is the validated baseline, not because I know of a hard conflict with every newer release.
Package armbian-config is not available
Werner replied to Dyfcom's topic in Software, Applications, Userspace
https://github.com/armbian/configng/releases -
Sancho replied to Sancho's topic in Rockchip CPU Boxes
@rosic shared it on MEGA, to flash use the instruction provided on my github. MEGA links: Rom - https://mega.nz/file/10wE1I6D#kMIPehB7qj5D9j6I1hw4aIUhGXMs7ZJsQgUnVFQfNEA Checksum - https://mega.nz/file/koh3HSJL#tbUEWwE-cNw1eo9HM4m15Qu0ax9D057HFTgoXd9wvmA -
I think that the comment by @werner was mostly intended to set your expectations. Based on what you have said, you have a board that Armbian doesn't support at all. Second, you have found a similar board (Bpi M2 Ultra) that exists within Armbian. But that board is a csc board (Community Support). Which means it also isnt' supported by Armbian. But some developer in the community has as some point in the past contributed some work on it. Likely that developer no longer is around and that board doesn't get any meaningful maintenance. So you are doing the proper thing in using these forums to post your observation and question. But unless either you or some other volunteer in the community wants to work on this, it is unlikely to ever get much if any attention. That is the reality of a SBC world where the manufacturers don't support the software on their boards and the volunteers at Armbian can only work to support a few boards directly while providing the tools and framework for other community volunteers to add in partial support for some other boards.
Using compile.sh for Orange Pi, PCIe/NVMe not working
teslik replied to ScottN's topic in Advanced users - Development
I know this is an old post, but I am desperate and saw you are using v 1.3.2. I have an Orange Pi 5 v 1.3.2 as well and I can't get it to boot. I have been trying a bunch of different OS's, Ubuntu and Ambian versions and it keeps failing. ChatGPT and Gemini both say it is a bad DBT file and then point me to the same version of Ambian to use. None of it seems to work, have you had any luck getting it to work? I haven't tried compiling the OS yet for it, I was hoping there was a stable version out there I could use. - Yesterday
epost.deb replied to fedes_gl's topic in Rockchip CPU Boxes
Android DTB itself is broken in many ways, mainly because wifi gpios from DTB do not show up in the gpioinfo output. It is more important to put the brcm4335-sdio firmware in /lib/firmware/brcm, which is missing in the armbian repository. iw phy0 info shows support of the 5GHz channels, but i don't have such access points nearby. I will check tomorrow with my dual-band AP. -
It happened a few days ago that I rebuilt my complete firmware package to try something with another device. An HC4 firmware binary also automatically falls out in this process. If you like, you can put it on a microSD card (dd bs=512 seek=1 conv=notrunc,fsync if=u-boot-meson.bin of=/dev/${entire-device-to-be-used}), place the prepared microSD card in your HC4 and start it with the boot button pressed. Check whether it meets your expectations, and if all tests are successful, you can transfer it to the SPI flash.
How you can help test upcoming Armbian 26.05 images?
Stephen Graf replied to Igor's topic in Advanced users - Development
Board: Orangepione Testing results for the three available images. Should there be more images available? Armbian_26.5.1_Orangepione_resolute_current_6.18.33_minimal.img Tested working: Boot from SD card with uboot and then to a USB SSD. Reboot Connect via ssh iperf3 after installing iperf3 gpio after installing gpiod HDMI video HDMI audio after installing mpg123 Used usb keyboard/mouse to test HDMI. Note that resolute now uses gpiod for gpio instead of sys. Gpiod had to be installed whereas trixie minimal comes with gpiod installed. Armbian_2Armbian_26.5.1_Orangepione_trixie_current_6.18.33_minimal.img Tested working: Boot from SD card with uboot and then to a USB SSD. Reboot Connect via ssh iperf3 after installing iperf3 gpio HDMI video HDMI audio after installing mpg123 Used usb keyboard/mouse to test HDMI. Armbian_26.5.1_Orangepione_resolute_current_6.18.33_xfce_desktop.img Tested working: Boot from SD card with uboot and then to a USB SSD. Reboot On HDMI connecter screen with usb keyboard/mouse Using terminal emulatori tested perf3 and gpio HDMI audio with vlc media player. Not working: Ran chromium to get to Armbian download page but took over a minute for each page to load and then the system crashed. With only 512MB RAM this system is under powered for general purpose desktop use. ubuntu_resolute_minimal.txt debian_trixie_minimal.txt ubuntu_resolute_xfce.txt -
I recognize this is an old thread - but there are no newer ones open and I figure having one thread instead of many is best. I'm trying to do the same thing as you OP, getting a raspberry pi DSI display working on a rockpi 4b+. I tried to adapt Radxa's DTS in a similar way you did from Armbian's Base DTS, and seeing what definitions changed and I came up with this non working DTS: Which gives the following DMESG error, very similar to yours: `[ 21.477004] rpi-ts-dsi ff960000.dsi.0: failed to attach dsi to host: -517 [ 21.477086] mipi-dsi ff960000.dsi.0: deferred probe pending: (reason unknown)` You'll note various differences between our DTS, like panel_in instead of panel_in_dsi, and mipi_dsi instead of mipi_dsi1. I based these off looking at the base DTS in Armbian kernel 6.18.32, but also on this project I found recently that brings support for 7 and 10 inch Osoyoo brand of DSI panels to the RockPi 4b+. I think that's really promising and will help with bringing DTS support to the raspberry pi panel (and others that are compatible). I recommend you look into it. I will continue iterating and update this thread with results if any. I don't think OP was pinning the problem on Armbian. OP was asking how to configure a custom DTS to work with the hardware they have. This is the community support forum, which is the correct place for this kind of discussion.
Helios64 hangs with 26.2.1 / 6.18.10 kernel on cpu5
Astra7525 replied to SymbiosisSystems's topic in Rockchip
You could flash armbian to an SDcard, then set Jumper P10 to force UBoot to skip booting from EMMC and pick the sdcard instead. From there you can directly mount the internal storage and chroot into it to run armbian-config and enable the overlay. - Last week
https://libre.computer/products/roc-rk3399-pc/ Can the computer run entirely on free software which is software you can use, share, modify and redistribute? The question includes firmware, microcode, etc, any piece of software that is running on the computer. If some devices on the computer requires non free software in order to work then what devices are they? And will the computer still work if you choose to not install the pieces of non free software in question? Thank you.
For those who want to compile from source: a) locate file ~ /armbian-build-mxpro/patch/kernel/archive/sunxi-6.12/series.conf b) delete the following lines before issuing ./compile.sh: spi-rockchip-Fix-runtime-PM-and-other-issues and spi-fixes c) save the file and proceed to compilation (./compile.sh) Note: if you want to upgrade the Armbian firmware be aware that: linux-dtb-current-sunxi64/trixie 26.5.1 arm64 [upgradable from: 26.02.0-trunk] linux-image-current-sunxi64/trixie 26.5.1 arm64 [upgradable from: 26.02.0-trunk] will render the ethernet interface inoperable. You can prevent this by issuing sudo apt-mark hold armbian-firmware before sudo apt upgrade -y
Is it possible to change the boot order? For my use case, I would like the boot priority to be: eMMC, NVMe, and microSD card. Can this be configured?
I've created a guide here how to run a Home Assistant OS suprisingly it run mostly natively. Didn't do anything except replacing the DTB. Also right away flashed it into a emmc. On my board emmc is from Samsung and has a read speed on 180Mb/s...
I'd like to run the mainline kernel https://github.com/nickfox-taterli/avaota-a1-mainline-linux The board used to have a page and downloads here: https://armbian.com/boards/avaota-a1 but it's gone. Has support for this board been dropped?
Ask AI to fix problems at repo level: https://github.com/armbian/supervised-installer so we can all benefit. I don't have capacity to maintain this alone. -
Proprietary DDR and maskrom images from Rockchip Bare metall should provide DDR init replacement code, the only missing part in u-boot.
