GeraltOfTrivia Posted September 16, 2019 Posted September 16, 2019 On 9/16/2019 at 2:10 PM, dolphs said: Now that Kernel 5.3 has seen the light I wonder where things stand if I'd build with these options " BOARD=orangepioneplus BRANCH=dev RELEASE=buster BUILD_MINIMAL=yes BUILD_DESKTOP=no KERNEL_ONLY=no KERNEL_CONFIGURE=no " for OrangePiOneplus . I suppose a working image ( read: bootable ) can be build? Also can things rgd OPiOnePlus be moved to a matured status, or that needs to wait at least till a new LTS Kernel 5.4 will pop up somewhere in November ? Expand I know this doesn't exactly answer your question, but the only way (at least for me) to get a working image for OPiOnePlus is to either copy a dtb file from an older image (kernel 5.1.5 and older works for me) to the new erimages or edit the dtb file of newer images and copy over the cpu opp table values from an older image (5.1.5 and older) to the new image. Otherwise I'm just stuck with endless bootloops. Makes no difference if I built the image myself or downloaded a pre-built one. 0 Quote
Werner Posted September 16, 2019 Posted September 16, 2019 I have two OPi1+ and both running fine on 5.3.0 and earlier ran fine on 5.2.x as well... Just updated one of those SBCs to the 5.3.0-sunxi64 kernel image I built earlier today (and is available to the public, see link below) and is booting fine. 0 Quote
leofuscaldi Posted September 16, 2019 Posted September 16, 2019 I have tried on my OPi3 the latest 5.3 nightly Buster and Buster Minimal, trying with USB power and DC connector 3A PS. It crashed in all cases.... 0 Quote
sadnblueish Posted September 16, 2019 Posted September 16, 2019 Upgraded to #5.97.190916 an hour ago and noticed Thermal reading is back. Left the system complete idle for an hour. After hour, I noticed thermal reading of 58C while ambient is 26C. It has a good heatsink installed. I remember old days on the board when it was that hot or may be more in idle state. 0 Quote
SchmuseTigger Posted September 17, 2019 Posted September 17, 2019 On 9/16/2019 at 11:06 PM, sadnblueish said: Upgraded to #5.97.190916 an hour ago and noticed Thermal reading is back. Left the system complete idle for an hour. After hour, I noticed thermal reading of 58C while ambient is 26C. It has a good heatsink installed. I remember old days on the board when it was that hot or may be more in idle state. Expand 64° while running stuff like PiHole. And yes has a heatsink but now fan running right now. But yes, seems higher then before. 0 Quote
dolphs Posted September 17, 2019 Posted September 17, 2019 On 9/17/2019 at 8:52 AM, SchmuseTigger said: 64° while running stuff like PiHole. And yes has a heatsink but now fan running right now. But yes, seems higher then before. Expand What shows your output " cpufreq-info |grep governor " - Should be ondemand I suppose, or set to anything else - eg performance? Perhaps "conservative" is a nicer way for your situation ramping up step by step to reduce CPU temp ( cpufreq-set -g conservative ) ... Anyway will build ( BOARD=orangepioneplus BRANCH=dev RELEASE=buster BUILD_MINIMAL=yes BUILD_DESKTOP=no KERNEL_ONLY=no KERNEL_CONFIGURE=no ) and flash my H6 OPiOnePlus later today , or is 5.3 already in default branch ( stable? ) 0 Quote
Werner Posted September 17, 2019 Posted September 17, 2019 On 9/17/2019 at 10:00 AM, dolphs said: or is 5.3 already in default branch ( stable? ) Expand From Armbians point of view it is still the dev branch. Though the linux source repository has been updated to 5.3.0 stable release. 0 Quote
GeraltOfTrivia Posted September 17, 2019 Posted September 17, 2019 On 9/16/2019 at 6:08 PM, Werner said: I have two OPi1+ and both running fine on 5.3.0 and earlier ran fine on 5.2.x as well... Just updated one of those SBCs to the 5.3.0-sunxi64 kernel image I built earlier today (and is available to the public, see link below) and is booting fine. Expand I've seen in your signature that you have OPi1+s, I've even tried some of your pre-built images, but mine refuses to boot unless I use a pre 5.1.5 dtb or modify the cpu opp table. Weird, but as long as there's a workaround, I'm not complaining. 0 Quote
sadnblueish Posted September 17, 2019 Posted September 17, 2019 CPU heating up badly. Ambient 26C with heatsink installed. #5.97.190917 Welcome to Debian Buster with Armbian Linux 5.3.0-sunxi64 System load: 0.00 0.00 0.00 Up time: 4:12 hours Memory usage: 5 % of 1993MB IP: 192.168.0.102 CPU temp: 63°C Usage of /: 25% of 7.1G No hidden system load generator processes 0 Quote
Werner Posted September 17, 2019 Posted September 17, 2019 Welcome to Debian Buster with Armbian Linux 5.3.0-sunxi64 System load: 0.00 0.00 0.00 Up time: 22:28 hours Memory usage: 9 % of 988MB IP: CPU temp: 54°C No heat sink, about 22°C environment. 0 Quote
Igor Posted September 17, 2019 Posted September 17, 2019 On 9/17/2019 at 2:15 PM, Werner said: or is 5.3 already in default branch ( stable? ) Expand From there to (end user want to have) stable and minimal Armbian stable standards is still a lot of work. Upstream stable branches are more or less important for us, since we have a new reference point and most likely next stable-to-be kernel. IMO 5.3.y is the only way to cover H6 devices ... porting to 4.19.y is futile. 0 Quote
SchmuseTigger Posted September 19, 2019 Posted September 19, 2019 On 9/17/2019 at 10:00 AM, dolphs said: What shows your output " cpufreq-info |grep governor " - Should be ondemand I suppose, or set to anything else - eg performance? Perhaps "conservative" is a nicer way for your situation ramping up step by step to reduce CPU temp ( cpufreq-set -g conservative ) ... Anyway will build ( BOARD=orangepioneplus BRANCH=dev RELEASE=buster BUILD_MINIMAL=yes BUILD_DESKTOP=no KERNEL_ONLY=no KERNEL_CONFIGURE=no ) and flash my H6 OPiOnePlus later today , or is 5.3 already in default branch ( stable? ) Expand CPU temp: 62°C Usage of /: 61% of 7.1G Last login: Tue Sep 17 08:51:11 2019 from 192.168.178.20 root@orangepi3:~# cpufreq-info |grep governor available cpufreq governors: conservative, userspace, powersave, ondemand, performance, schedutil The governor "ondemand" may decide which speed to use available cpufreq governors: conservative, userspace, powersave, ondemand, performance, schedutil The governor "ondemand" may decide which speed to use available cpufreq governors: conservative, userspace, powersave, ondemand, performance, schedutil The governor "ondemand" may decide which speed to use available cpufreq governors: conservative, userspace, powersave, ondemand, performance, schedutil The governor "ondemand" may decide which speed to use not sure why the output was 4 times the same, but that is how it looked on my side. 0 Quote
guidol Posted September 20, 2019 Posted September 20, 2019 On 9/19/2019 at 9:07 PM, SchmuseTigger said: not sure why the output was 4 times the same, but that is how it looked on my side. Expand thats easy cpufreq-info will show the governor for every of your 4 CPUs: CPUs which run at the same hardware frequency: 0 1 2 3 CPUs which need to have their frequency coordinated by software: 0 1 2 3 analyzing CPU 0: analyzing CPU 1: analyzing CPU 2: analyzing CPU 3: 0 Quote
dolphs Posted September 20, 2019 Posted September 20, 2019 On 9/19/2019 at 9:07 PM, SchmuseTigger said: CPU temp: 62°C Expand still ondemand, try with conservative .. might result few degrees lower .. though temperature is rather high imho should be +/- 40 degrees ( depending whether idle or not ) 0 Quote
SchmuseTigger Posted September 20, 2019 Posted September 20, 2019 On 9/20/2019 at 11:58 AM, dolphs said: still ondemand, try with conservative .. might result few degrees lower .. though temperature is rather high imho should be +/- 40 degrees ( depending whether idle or not ) Expand yes, after the change it says conservative, but temp still 60+ 0 Quote
SchmuseTigger Posted September 20, 2019 Posted September 20, 2019 On 9/20/2019 at 11:58 AM, dolphs said: still ondemand, try with conservative .. might result few degrees lower .. though temperature is rather high imho should be +/- 40 degrees ( depending whether idle or not ) Expand that makes so much sense. So you could run the cores differently? But even after updating to latest version and going to slower governor still kinda hot 0 Quote
062621AM Posted October 6, 2019 Posted October 6, 2019 can i request suggestion on images to try? My orangepi3 always stuck at [] A start job is running for Armbian filesystem resize (xmin xs / xmin xs) <- xmin and xs is what i wrote because it's not always stuck at the same value Flashed using Etcher (Ubuntu) and then switched to Win32DiskImager (Windows 10) Tested with 2 different SD cards but the SD cards able to flash Ubuntu desktop image from OrangePi using the script, OrangePi_install2EMMC.sh included inside Ubuntu desktop image from OrangePi http://www.orangepi.org/downloadresources/OrangePi3/2019-01-23/orangepi3_82ad209229e957e13fa953491c.html i tried: Armbian_5.98.191006_Orangepi3_Debian_buster_dev_5.3.3_minimal.img Armbian_5.90_Orangepi3_Ubuntu_bionic_dev_5.1.15 Armbian_5.90_Orangepi3_Debian_buster_dev_5.1.15 Below is the serial console output (Armbian_5.98.191006_Orangepi3_Debian_buster_dev_5.3.3_minimal): Reveal hidden contents U-Boot SPL 2019.04-armbian (Oct 06 2019 - 03:05:46 +0200) DRAM: 2048 MiB Trying to boot from MMC1 NOTICE: BL31: v2.1(debug):cf9319f-dirty NOTICE: BL31: Built : 03:05:39, Oct 6 2019 NOTICE: BL31: Detected Allwinner H6 SoC (1728) NOTICE: BL31: Found U-Boot DTB at 0xc079e78, model: OrangePi 3 INFO: ARM GICv2 driver initialized NOTICE: PMIC: Probing AXP805 NOTICE: PMIC: AXP805 detected INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services INFO: BL31: cortex_a53: CPU workaround for 855873 was applied INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 U-Boot 2019.04-armbian (Oct 06 2019 - 03:05:46 +0200) Allwinner Technology CPU: Allwinner H6 (SUN50I) Model: OrangePi 3 DRAM: 2 GiB MMC: mmc@4020000: 0, mmc@4022000: 1 Loading Environment from EXT4... ** File not found /boot/boot.env ** ** Unable to read "/boot/boot.env" from mmc0:1 ** In: serial@5000000 Out: serial@5000000 Err: serial@5000000 Net: No ethernet found. starting USB... No controllers found Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3042 bytes read in 1 ms (2.9 MiB/s) ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from mmc 116 bytes read in 1 ms (113.3 KiB/s) 29583 bytes read in 8 ms (3.5 MiB/s) 4161 bytes read in 5 ms (812.5 KiB/s) Applying kernel provided DT fixup script (sun50i-h6-fixup.scr) ## Executing script at 44000000 7212285 bytes read in 731 ms (9.4 MiB/s) 15618056 bytes read in 1579 ms (9.4 MiB/s) ## Loading init Ramdisk from Legacy Image at 4fe00000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 7212221 Bytes = 6.9 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 4fa00000 Booting using the fdt blob at 0x4fa00000 Loading Ramdisk to 4991f000, end 49fffcbd ... OK Loading Device Tree to 00000000498af000, end 000000004991efff ... OK Starting kernel ... h2testw_1.4 Test Result: Reveal hidden contents Warning: Only 60812 of 60903 MByte tested. Test finished without errors. You can now delete the test files *.h2w or verify them again. Writing speed: 29.1 MByte/s Reading speed: 77.7 MByte/s H2testw v1.4 OrangePi_install2EMMC.sh content if anyone is interested: Reveal hidden contents #!/bin/bash if [ "$(id -u)" != "0" ]; then echo "Script must be run as root !" exit 0 fi _format=${1} fatsize=64 sdcard="/dev/mmcblk0" odir="/tmp/_extdir" bootdir="/tmp/_fatdir" if [ ! -b ${sdcard}boot0 ]; then echo "Error: EMMC not found." exit 1 fi if [ ! -f /opt/boot/boot0.bin ]; then echo "Error: /opt/boot/boot0.bin not found." exit 1 fi if [ ! -f /opt/boot/uboot.bin ]; then echo "Error: /opt/boot/uboot.bin not found." exit 1 fi umount ${sdcard}* > /dev/null 2>&1 #---------------------------------------------------------- echo "" echo -n "WARNING: EMMC WILL BE ERASED !, Continue (y/N)? " read -n 1 ANSWER if [ ! "${ANSWER}" = "y" ] ; then echo "." echo "Canceled.." exit 0 fi echo "" #---------------------------------------------------------- echo "Erasing EMMC ..." dd if=/dev/zero of=${sdcard} bs=1M count=32 > /dev/null 2>&1 sync sleep 1 echo "Creating new filesystem on EMMC ..." echo -e "o\nw" | fdisk ${sdcard} > /dev/null 2>&1 sync echo " New filesystem created on $sdcard." sleep 1 partprobe -s ${sdcard} > /dev/null 2>&1 if [ $? -ne 0 ]; then echo "ERROR." exit 1 fi sleep 1 echo "Partitioning EMMC ..." sfat=40960 efat=$(( $fatsize * 1024 * 1024 / 512 + $sfat - 1)) echo " Creating boot & linux partitions" sext4=$(( $efat + 1)) eext4="" echo -e "n\np\n1\n$sfat\n$efat\nn\np\n2\n$sext4\n$eext4\nt\n1\nb\nt\n2\n83\nw" | fdisk ${sdcard} > /dev/null 2>&1 echo " OK." sync sleep 2 partprobe -s ${sdcard} > /dev/null 2>&1 if [ $? -ne 0 ]; then echo "ERROR." exit 1 fi sleep 1 echo "Formating fat partition ..." dd if=/dev/zero of=${sdcard}p1 bs=1M count=1 oflag=direct > /dev/null 2>&1 sync sleep 1 mkfs.vfat -n EMMCBOOT ${sdcard}p1 > /dev/null 2>&1 if [ $? -ne 0 ]; then echo " ERROR formating fat partition." exit 1 fi echo " fat partition formated." dd if=/dev/zero of=${sdcard}p2 bs=1M count=1 oflag=direct > /dev/null 2>&1 sync sleep 1 echo "Formating linux partition (ext4), please wait ..." mkfs.ext4 -L emmclinux ${sdcard}p2 > /dev/null 2>&1 if [ $? -ne 0 ]; then echo "ERROR formating ext4 partition." exit 1 fi echo " linux partition formated." #************************************************************************ echo "" echo "Instaling u-boot to EMMC ..." dd if=/opt/boot/boot0.bin of=${sdcard} bs=1k seek=8 > /dev/null 2>&1 if [ $? -ne 0 ]; then echo "ERROR installing u-boot." exit 1 fi dd if=/opt/boot/uboot.bin of=${sdcard} bs=1k seek=16400 > /dev/null 2>&1 if [ $? -ne 0 ]; then echo "ERROR installing u-boot." exit 0 fi sync #************************************************************************ # ------------------------------------------------------------------- if [ ! -d $bootdir ]; then mkdir -p $bootdir fi rm $bootdir/* > /dev/null 2>&1 sync umount $bootdir > /dev/null 2>&1 if [ ! -d $odir ]; then mkdir -p $odir fi rm -rf $odir/* > /dev/null 2>&1 sync umount $odir > /dev/null 2>&1 sleep 1 # ================ # MOUNT PARTITIONS # ================ _mntopt="" echo "" echo "Mounting EMMC partitions..." if ! mount ${sdcard}p1 $bootdir; then echo "ERROR mounting fat partitions..." exit 1 fi if ! mount ${_mntopt} ${sdcard}p2 $odir; then echo "ERROR mounting linux partitions..." umount $bootdir exit 1 fi echo "FAT partitions mounted to $bootdir" echo "linux partition mounted to $odir" #----------------------------------------------------------------------------------------------- echo "" echo "Copying file system to EMMC ..." echo "" #----------------------------------------------------------------------------------------- rsync -r -t -p -o -g -x --delete -l -H -D --numeric-ids -s --stats / $odir/ > /dev/null 2>&1 if [ $? -ne 0 ]; then echo " ERROR." fi #----------------------------------------------------------------------------------------- sync echo " Creating \"fstab\"" echo "# OrangePI fstab" > $odir/etc/fstab if [ "${_format}" = "btrfs" ] ; then echo "/dev/mmcblk0p2 / btrfs subvolid=0,noatime,nodiratime,compress=lzo 0 1" >> $odir/etc/fstab else echo "/dev/mmcblk0p2 / ext4 errors=remount-ro,noatime,nodiratime 0 1" >> $odir/etc/fstab fi echo "/dev/mmcblk0p1 /media/boot vfat defaults 0 0" >> $odir/etc/fstab echo "tmpfs /tmp tmpfs nodev,nosuid,mode=1777 0 0" >> $odir/etc/fstab sync #----------------------------------------------------------------------------------------- rsync -r -t -p -o -g -x --delete -l -H -D --numeric-ids -s --stats /boot/ $bootdir/ > /dev/null 2>&1 if [ $? -ne 0 ]; then echo " ERROR." fi #----------------------------------------------------------------------------------------- cp /opt/boot/uEnv.txt $bootdir/ sync # UMOUNT if ! umount $bootdir; then echo "ERROR unmounting fat partition." exit 1 fi rm -rf $bootdir/* > /dev/null 2>&1 rmdir $bootdir > /dev/null 2>&1 if ! umount $odir; then echo "ERROR unmounting linux partitions." exit 0 fi rm -rf $odir/* > /dev/null 2>&1 rmdir $odir > /dev/null 2>&1 sync echo "" echo -e "\033[36m*******************************" echo "Linux system installed to EMMC." echo -e "*******************************\033[37m" setterm -default echo "" exit 0 0 Quote
Teikahym Posted October 7, 2019 Posted October 7, 2019 On 9/8/2019 at 8:22 AM, krachlatte said: [ 4930.512612] Internal error: SP/PC alignment exception: 8a000000 [#1] SMP [ 4930.519320] Modules linked in: xt_MASQUERADE nf_conntrack_netlink nfnetlink xfrm_user xfrm_algo iptable_nat xt_addrtype iptable_filter xt_conntrack nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 br_netfilter bridge nls_utf8 cifs fscache libarc4 aufs overlay bnep zstd zram fuse snd_soc_hdmi_codec snd_soc_core snd_pcm_dmaengine snd_pcm snd_timer snd soundcore btsdio bluetooth brcmfmac brcmutil ch341 usbserial uas cfg80211 rfkill dw_hdmi_cec dw_hdmi_i2s_audio panfrost gpu_sched cpufreq_dt realtek i2c_mv64xxx dwmac_sun8i mdio_mux [ 4930.566124] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 5.3.0-rc6-sunxi64 #5.96.190908 [ 4930.573854] Hardware name: OrangePi 3 (DT) [ 4930.577944] pstate: 80000085 (Nzcv daIf -PAN -UAO) [ 4930.582731] pc : 0x7fffffffffffffff [ 4930.586220] lr : __hrtimer_run_queues+0x170/0x210 [ 4930.590915] sp : ffff000010003e50 [ 4930.594224] x29: ffff000010003e50 x28: ffff8000730d5500 [ 4930.599528] x27: ffff800077b80d40 x26: 0000000000000060 [ 4930.604830] x25: 0000000000000080 x24: 15c26873e65a79bb [ 4930.610134] x23: 0000000000000001 x22: 0000000000000000 [ 4930.615438] x21: 0000000000000001 x20: ffff800077b80d00 [ 4930.620732] x19: ffff800077b80d80 x18: 0000000000000000 [ 4930.626035] x17: 0000000000000000 x16: 0000000000000000 [ 4930.631339] x15: 0000000000000000 x14: 0000000000000000 [ 4930.636643] x13: 0000000000000001 x12: 0000000000034079 [ 4930.641946] x11: 0000000000000000 x10: 0000000000000040 [ 4930.647250] x9 : ffff000010e62b38 x8 : ffff000010e62b30 [ 4930.652554] x7 : ffff000010e32980 x6 : ffff800077b80d00 [ 4930.657857] x5 : ffff00001222b850 x4 : 0000047bf68e2800 [ 4930.663152] x3 : ffff00001222b850 x2 : 0000047bf68e2800 [ 4930.668456] x1 : 0000000000000006 x0 : 0000000000000004 [ 4930.673760] Call trace: [ 4930.676203] 0x7fffffffffffffff [ 4930.679340] hrtimer_interrupt+0xf8/0x2d0 [ 4930.683347] arch_timer_handler_phys+0x28/0x40 [ 4930.687785] handle_percpu_devid_irq+0x80/0x140 [ 4930.692311] generic_handle_irq+0x24/0x38 [ 4930.696315] __handle_domain_irq+0x5c/0xb0 [ 4930.700406] gic_handle_irq+0x58/0xa8 [ 4930.704062] el1_irq+0xb8/0x140 [ 4930.707198] arch_cpu_idle+0x10/0x18 [ 4930.710769] do_idle+0x1e0/0x2c0 [ 4930.713992] cpu_startup_entry+0x20/0x28 [ 4930.717910] rest_init+0xb4/0xc0 [ 4930.721133] arch_call_rest_init+0xc/0x14 [ 4930.725136] start_kernel+0x44c/0x478 [ 4930.728797] Code: bad PC value [ 4930.731847] ---[ end trace c5dcc02a219943cf ]--- [ 4930.736458] Kernel panic - not syncing: Fatal exception in interrupt [ 4930.742804] SMP: stopping secondary CPUs [ 4930.746722] Kernel Offset: disabled [ 4930.750205] CPU features: 0x0002,20002004 [ 4930.754207] Memory Limit: none [ 4930.757259] Rebooting in 10 seconds.. does not look that good the latest version , switching pack the dtb file also this problem shows up cat /sys/class/thermal/thermal_zone0/temp: invalid argument Expand looks like we have the same problem. 5.88.190601 is the last bootable version for my board. If you want newer versions you have to hold the dtb: apt-mark hold linux-dtb-dev-sunxi64 and upgrade from there. My guess is its the new lowered voltage table:https://github.com/armbian/build/blob/master/patch/kernel/sunxi-dev/0012-general-h6-new-opp-table.patch Since then some experience stability issues and others like myself are not even able to fully boot up without random kernel panics. 0 Quote
Igor Posted October 7, 2019 Posted October 7, 2019 On 10/7/2019 at 3:20 PM, Teikahym said: My guess is its the new lowered voltage table: Expand Possible. Now how we are going to get to the table that works well for all? All my H6 tests boards works fine with stock settings which are bad for you. On 10/6/2019 at 12:36 PM, 062621AM said: OrangePi_install2EMMC.sh content if anyone is interested: Expand https://docs.armbian.com/User-Guide_Getting-Started/#how-to-install-to-emmc-nand-sata-usb 0 Quote
megi Posted October 7, 2019 Posted October 7, 2019 5.4-rc1 contains patch to support using multiple DVFS tables based on H6 SoC speed bin. There are 3 bins slow/normal/fast and depending on which you happen to have on your board, you may lower the voltages for the same frequency. The fastest bin can deal with the lower voltages. Until this is configured in the DTS, everyone needs to use values for the worst bin (that is, to use higher voltages), because kernel can't assume it's running on a better bin. 1 Quote
062621AM Posted October 7, 2019 Posted October 7, 2019 On 10/7/2019 at 4:43 PM, megi said: 5.4-rc1 contains patch to support using multiple DVFS tables based on H6 SoC speed bin. There are 3 bins slow/normal/fast and depending on which you happen to have on your board, you may lower the voltages for the same frequency. The fastest bin can deal with the lower voltages. Until this is configured in the DTS, everyone needs to use values for the worst bin (that is, to use higher voltages), because kernel can't assume it's running on a better bin. Expand Is there a way to check the speed bin and how do I set the values? 0 Quote
AZ8 Posted October 7, 2019 Posted October 7, 2019 No boot after today upgrade and reboot U-boot wroks fine. Is it possible to recover system without reflash? 0 Quote
AZ8 Posted October 7, 2019 Posted October 7, 2019 => boot switch to partitions #0, OK mmc1(part 0) is current device Scanning mmc 1:1... Found U-Boot script /boot/boot.scr 3042 bytes read in 1 ms (2.9 MiB/s) ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from mmc 165 bytes read in 1 ms (161.1 KiB/s) Card did not respond to voltage select! libfdt fdt_check_header(): FDT_ERR_BADMAGIC No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! Bad Linux ARM64 Image magic! SCRIPT FAILED: continuing... Card did not respond to voltage select! starting USB... No controllers found USB is stopped. Please issue 'usb start' first. starting USB... No controllers found No ethernet found. missing environment variable: pxeuuid missing environment variable: bootfile Retrieving file: pxelinux.cfg/00000000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/0000000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/000000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/00000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/0000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/00 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/0 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/default-arm-sunxi No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/default-arm No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/default No ethernet found. Config file not found starting USB... No controllers found No ethernet found. No ethernet found. 0 Quote
062621AM Posted October 8, 2019 Posted October 8, 2019 On 10/7/2019 at 8:34 PM, AZ8 said: No boot after today upgrade and reboot U-boot wroks fine. Is it possible to recover system without reflash? Expand How do you check the U-Boot? 0 Quote
AZ8 Posted October 8, 2019 Posted October 8, 2019 On 10/8/2019 at 5:50 AM, 062621AM said: How do you check the U-Boot? Expand Maybe I am wrong, but uBoot has version with timestamp like 201904, therefore I assume it was not change during last upgrade. 0 Quote
AZ8 Posted October 8, 2019 Posted October 8, 2019 Is it possible to boot from sd and recover /boot on mmc? 0 Quote
062621AM Posted October 9, 2019 Posted October 9, 2019 On 10/8/2019 at 2:21 PM, AZ8 said: Is it possible to boot from sd and recover /boot on mmc? Expand If not mistaken, the board will always boot from SD card. 0 Quote
AZ8 Posted October 9, 2019 Posted October 9, 2019 Wrote latest image to SD Boot from SD mounted /dev/mmcblk2p1, copied armbianEnv.txt formated /dev/mmcblk2p1 rsync /boot to /dev/mmcblk2p1 copy armbianEnv.txt to /dev/mmcblk2p1 removed sd and reboot system starts to boot, but can not find root Is this a proper way to install boot? I do not want to tun nand-sata-install and erase mmc. 0 Quote
Watire Posted October 9, 2019 Posted October 9, 2019 I remember once, I had to modify /etc/fstab to direct / to the right uuid to get a booting system. 0 Quote
megi Posted October 10, 2019 Posted October 10, 2019 On 10/7/2019 at 5:25 PM, 062621AM said: Is there a way to check the speed bin and how do I set the values? Expand Yes, reading the bin is part of the commit f328584f7bff86858249bb358f1adcecde48388a It's store in SID memory, as a part of ChipID bytes. https://patchwork.kernel.org/patch/10903381/ How to set values is docummented in the dt-bindings patch. 1 Quote
