renedis Posted June 22, 2019 Posted June 22, 2019 Tried to do something with bluetooth, but "hcitool" and "bluetoothctl" tells me that there is no bluetooth controller. Anybody got this working yet? 0 Quote
SchmuseTigger Posted June 23, 2019 Posted June 23, 2019 On 6/22/2019 at 5:35 PM, renedis said: Tried to do something with bluetooth, but "hcitool" and "bluetoothctl" tells me that there is no bluetooth controller. Anybody got this working yet? Expand yes, check the thread called bluethooth. I did not manage to make it work, but somebody did. So good luck. 0 Quote
data Posted June 24, 2019 Posted June 24, 2019 In order to make bluetooth work, you need to check if uart1 is declared properly in the dts/dtb and enabled. Then proceed with hcitool... 0 Quote
renedis Posted June 25, 2019 Posted June 25, 2019 Thanks, I don't know how to do that and I'm not a "dts/dtb expert". Is there any guide on how to get this going? (not just bluetooth, als odts/dtb in generally). I'm interested and eager to learn but don't know where to start with this. Edit: I have absolutely no idea what I'm doing... But found this out looking at the schematics: PIN Define CFG PL10 BT-WIFI-ON 1 PM0 WL-WAKE-AP 0 PM1 BT-WAKE-AP 0 PM2 AP-WAKE-BT 1 PM3 WL-REG-ON 1 PM3 BT-REG-ON 1 I also found out that the schematics are the same as the AP6255. Edit2: Also found this topic.... Maybe if I convert DTB to DTS (and back) and add this: /* There's the BT part of the AP6256 connected to that UART */ &uart1 { pinctrl-names = "default"; pinctrl-0 = <&uart1_pins>, <&uart1_rts_cts_pins>; uart-has-rtscts; status = "okay"; bluetooth { compatible = "brcm,bcm4345c5"; clocks = <&rtc 1>; clock-names = "lpo"; device-wakeup-gpios = <&r_pio 1 2 GPIO_ACTIVE_HIGH>; /* PM2 */ host-wakeup-gpios = <&r_pio 1 1 GPIO_ACTIVE_HIGH>; /* PM1 */ shutdown-gpios = <&r_pio 1 4 GPIO_ACTIVE_HIGH>; /* PM4 */ max-speed = <1500000>; }; }; And copy https://github.com/orangepi-xunlong/OrangePiH6_external/tree/master/ap6256 to: /lib/firmware/brcm/(BCM4345C5.hcd) Am I correct that it will it work then? (I'm using a OPi3) 0 Quote
SchmuseTigger Posted June 28, 2019 Posted June 28, 2019 if you get it to work, please write how you did it. Also 5.2 should have it working. 0 Quote
dziobak Posted July 1, 2019 Posted July 1, 2019 There is new and fixed update to linux-dtb-dev-sunxi64 version 5.90.190630. 0 Quote
data Posted July 1, 2019 Posted July 1, 2019 Have the changes been updated also in the Lite2 version? 0 Quote
dziobak Posted July 1, 2019 Posted July 1, 2019 On 7/1/2019 at 9:15 AM, data said: Have the changes been updated also in the Lite2 version? Expand Yes, but I tested new voltage values on OPi3 only, so be prepared (this can gives stability on Lite2 also or ... not) 0 Quote
krachlatte Posted July 2, 2019 Posted July 2, 2019 On 7/1/2019 at 9:01 AM, dziobak said: There is new and fixed update to linux-dtb-dev-sunxi64 version 5.90.190630. Expand works fine boots again 0 Quote
SchmuseTigger Posted July 2, 2019 Posted July 2, 2019 On 7/2/2019 at 6:51 AM, krachlatte said: works fine boots again Expand mine is 5.88 even with apt-get update and going to nightly build 0 Quote
data Posted July 6, 2019 Posted July 6, 2019 Ok, Lite2 boots fine now with the current updates. From what I see, uart1 is now enabled by default and listed as ttyS1 in dmesg. Any idea, why I still can not enable bluetooth via hciattach /dev/ttyS1 ... ? How can I test if uart1 is actually working? 0 Quote
dolphs Posted July 8, 2019 Posted July 8, 2019 hurrah kernel 5.2 has been released - so will check back next week ( 5.2.1? ) hoping to be able to compile a first dev build for my H6 ( opioneplus ) and be able to boot from it. 2 Quote
SchmuseTigger Posted July 8, 2019 Posted July 8, 2019 On 7/8/2019 at 9:45 AM, dolphs said: hurrah kernel 5.2 has been released - so will check back next week ( 5.2.1? ) hoping to be able to compile a first dev build for my H6 ( opioneplus ) and be able to boot from it. Expand I can't wait to finally use BT with my OP3 0 Quote
Igor Posted July 8, 2019 Posted July 8, 2019 On 7/8/2019 at 9:45 AM, dolphs said: hurrah kernel 5.2 has been released - so will check back next week ( 5.2.1? ) hoping to be able to compile a first dev build for my H6 ( opioneplus ) and be able to boot from it. Expand Most of the functionality is already in Armbian kernel for weeks/months so you will not notice much if any difference But before we can switch target to 5.2.y a bunch of patches https://github.com/armbian/build/tree/master/patch/kernel/sunxi-dev (functionality that will come in upstream in next 6 months) has to be manually adjusted to meet with 5.2.y. Help is more then welcome! Not today. In a few weeks. 0 Quote
SchmuseTigger Posted July 9, 2019 Posted July 9, 2019 On 7/8/2019 at 4:48 PM, Igor said: Most of the functionality is already in Armbian kernel for weeks/months so you will not notice much if any difference But before we can switch target to 5.2.y a bunch of patches https://github.com/armbian/build/tree/master/patch/kernel/sunxi-dev (functionality that will come in upstream in next 6 months) has to be manually adjusted to meet with 5.2.y. Help is more then welcome! Not today. In a few weeks. Expand Wait, I thought the CPU/GPU support only comes with 5.2? I mean automatically because it is in the Linux Kernel? And I still hope for BT 5.0 0 Quote
Igor Posted July 9, 2019 Posted July 9, 2019 On 7/9/2019 at 8:29 AM, SchmuseTigger said: I thought the CPU/GPU support only comes with 5.2 Expand This feature http://linux-sunxi.org/Sunxi-Cedrus is missing and it should come with 5.2.y but this does not mean it will just work out of the box ... On 7/9/2019 at 8:29 AM, SchmuseTigger said: And I still hope for BT 5.0 Expand Don't see any mentioning http://linux-sunxi.org/Linux_mainlining_effort 0 Quote
SchmuseTigger Posted July 10, 2019 Posted July 10, 2019 That would suck. I tried to get it to work using the description I found in the BT thread here in the forum, but it did not work. Sucks as the files exist for 4 month to make BT 5.0 work but for a Linux newbie even with tinkering for hours I could not make it work. 0 Quote
AZ8 Posted July 16, 2019 Posted July 16, 2019 As per http://linux-sunxi.org/Linux_mainlining_effort Watchdog support for H6 merged into 5.3 Is it possible to use hw watchdog now? Maybe, compile some kernel module? 0 Quote
krachlatte Posted July 17, 2019 Posted July 17, 2019 Hi guys, following probelm happens over night, this are the console messages, received [87292.871955] rcu: INFO: rcu_sched detected stalls on CPUs/tasks: [87292.877889] rcu: 0-...0: (2 GPs behind) idle=92a/0/0x1 softirq=1158340/1158341 fqs=2486399 [87292.886312] rcu: (detected by 2, t=5046854 jiffies, g=3598193, q=16685) uname -a Linux orangepi3 5.1.16-sunxi64 #5.91.190708 SMP Tue Jul 9 00:38:37 CEST 2019 aarch64 aarch64 aarch64 GNU/Linux no i have set verbosity to 7 maybe i can post more tomorrow any idea ? 0 Quote
SchmuseTigger Posted July 31, 2019 Posted July 31, 2019 no clue. I have the buster version which does not work with a lot of software yet (no pi hole, no iobroker for instance), updates with apt-get show some errors and on the download section here the last update is weeks ago. Seems to be a low priority (not many people working on it). I personally wait for a good offer for a pi 4 and will just buy that, as it is supported by so many people. And then use the opie3 in a year or so for something else with the hope that the software will work then. 0 Quote
guidol Posted July 31, 2019 Posted July 31, 2019 On 7/31/2019 at 9:21 AM, SchmuseTigger said: no clue. I have the buster version which does not work with a lot of software yet (no pi hole, no iobroker for instance) Expand My last test - 5 days ago - does show that on a fresh installed "normal" buster pi-hole does work now fine 0 Quote
SchmuseTigger Posted August 2, 2019 Posted August 2, 2019 For me it did not even install Pi, got an error with apt-get and stopped after a few seconds into the install. But does not change that if you go https://dl.armbian.com/orangepi3/ And check the dates on the latest updates that very much looks like a dead project to me. 0 Quote
guidol Posted August 2, 2019 Posted August 2, 2019 On 8/2/2019 at 8:23 AM, SchmuseTigger said: https://dl.armbian.com/orangepi3/ And check the dates on the latest updates that very much looks like a dead project to me. Expand the latest images there are from the 06.07.2019 - just a month old. Why should it be dead? Mostly these images do get the newest updates only online - not every time a new image would be created for all SBCs. 0 Quote
greg798 Posted August 3, 2019 Posted August 3, 2019 Hello Im build armbian 5.2.x (and mesa), but I don’t have enough tutorials to up panfrost on mali. Tell me, did someone manage to get him to work normally? 0 Quote
Werner Posted August 3, 2019 Posted August 3, 2019 On 8/2/2019 at 8:23 AM, SchmuseTigger said: For me it did not even install Pi, got an error with apt-get and stopped after a few seconds into the install. But does not change that if you go https://dl.armbian.com/orangepi3/ And check the dates on the latest updates that very much looks like a dead project to me. Expand Feel free to build your own image using the build script including the latest changes at any time 0 Quote
AZ8 Posted August 4, 2019 Posted August 4, 2019 On 8/3/2019 at 7:33 AM, Werner said: Feel free to build your own image using the build script including the latest changes at any time Expand Yeah, it is possible to build Armbian_5.93_Orangepi3_Debian_buster_dev_5.2.5.img I have a qustion: do you have a tutorial to set up apt server to update kernel/dtb instead of reflashing? 0 Quote
martinayotte Posted August 4, 2019 Posted August 4, 2019 On 8/4/2019 at 1:08 PM, AZ8 said: do you have a tutorial to set up apt server to update kernel/dtb instead of reflashing? Expand Do a build with "kernel+u-boot only", then copy output/debs/linux-image-dev-sunxi64_5.93_arm64.deb and output/debs/linux-dtb-dev-sunxi64_5.93_arm64.deb on the OPi using "scp". After logging into OPi with "ssh", simply do "dpkg -i linux*.deb" ... 1 Quote
sadnblueish Posted August 4, 2019 Posted August 4, 2019 On 8/2/2019 at 8:46 AM, guidol said: the latest images there are from the 06.07.2019 - just a month old. Why should it be dead? Mostly these images do get the newest updates only online - not every time a new image would be created for all SBCs. Expand Project nightly builds are suspended due to Kernel version upgrade (as I know) but sunxi platform is being actively worked at by devs. I keep looking at "https://github.com/armbian/build/commits/master" 0 Quote
Werner Posted August 4, 2019 Posted August 4, 2019 I added OPi 3 Buster image as well as kernel debs to my builds and will be available tomorrow following the link mentioned in my signature below. 1 Quote
