Release Candidate Code Freeze Date: 2022-02-14
Release Planning Meeting Date:  2022-01-29 14:00 UTC+1
Release Planning Meeting Location: Armbian IRC
Release Date: 2022-02-28
Release Branch Link: https://github.com/armbian/build/tree/v22.02
Release Changelog:
Release notes - Armbian - Version 22.02
Bug
AR-1101 DRM patch is failing on Rockchip
AR-1079 Ubuntu archive redirector is not providing best service
AR-1077 Fix RPi4 userland audio
AR-1069 First login doesn't pick up correct shell
AR-1065 Twitter forum registration is not working
AR-1063 X86 desktop images are not enabled in CI
AR-1062 When selecting repository install u-boot might not be flashed
AR-1055 Aptly repository seems to be out of business
AR-1048 Rpi kernel image is not updated on upgrade
AR-1043 linux-firmware repository change branch from "master" to "main"
AR-973 Helios64 boot building is failing after update to 2021.10
AR-871 Debian SID broken wallpaper
Story
AR-1074 Switch all CURRENT to 5.15.y and EDGE to 5.16.y
AR-1009 Armbian Framework extensions and UEFI support
Task
AR-1100 Support for Orange Pi R1 Plus LTS, Drivers for YT8531 and other Motorcomm chips. Linux-5.10y and Linux-5.15y.
AR-1084 Enable 3D support on Debian desktop
AR-1078 Add additional forum plugins and adjust settings
AR-1068 Add gnome-system-monitor to Focal and Jammy
AR-1049 Add ZFS that supports kernel 5.15.y
AR-1044 Improve Raspberry Pi support
AR-1041 JetHome: fix brcm (AP6255) firmware links
AR-1040 Refactor armbian-bsp-cli package creation
AR-931 Using Docker image for building kernels
AR-893 Cleanup rockchip64 u-boot scenarios
AR-757 Adding Raspberry Pi
AR-586 Implement fan controller for Nanopi M2V2
Release Coordinator: @Heisath and hopefully some new person on the team :)
Already creating this release topic for 22.02, to discuss upcoming changes, no longer maintained boards and help new people get into the release / maintain flow.
Current steps:
- Refine supported/WIP/CSC/etc. board status
- Update maintainer list
- Onboard new maintainers / contributors
- Move Jira issues to new release
- Select release name
@Igor @Werner @TonyMac32 @martinayotte @piter75 @ning @Myy @balbes150 @sfx2000 @ebin-dev @chwe  @gprovost @aprayoga @lanefu @5kft @JMCC @going @jeanrhum @dolphs @jock @belfastraven @TRS-80 @Bozza @Rich Neese @sgjava @Mangix @tony013  @rpardini
Pls. ping developers I forgot :)
  • Heisath changed the title to Armbian 22.02 (No name yet) Release Thread
  • lanefu featured and pinned this topic
Some of this is already in the works and should be done soon.
We also need to prepare and present communication strategy for new maintainers - basically just review what is expected within maintainer role:
https://forum.armbian.com/staffapplications/application/8-single-board-computer-maintainer/
and how we would like that things run. And take their suggestions. We want that those people feel good but also have healthy expectations.
And second meeting - technical one as we did in the past. Or we join all in one? Important is that new people (@yang is responsible for keeping the list updated) are invited there.
I would still go on with the February release, we skipped last one, lets get this one done.
Am targeting 2022-01-29 (Saturday, 29 of January 2022) for release meeting, and then about 4 weeks later 2022-02-25 (Friday, 25 of February 2022) for actual release.
Release meeting earlier than 2022-01-25 is not possible from my calendar.
  • lanefu changed the title to Armbian 22.02 (Pig) Release Thread
Improved testing on hardware - its attached to nightly builds and currently needs to be run manually:
badge.svg
  • connects to the device via SSH as root (ssh key must be there)
  • runs apt update + upgrade
  • reboots
  • waits 3 minutes that machine is back
  • true or false
  • power cycle the board in case of false (where we have power control)
Currently 38 boards are attached, but its very simple to add more of them.
57 минут назад, Igor сказал:
what about remote boards? I can connect jethub h1/d1 with power/reset/console remote control
Fixed some UX troubles on the download pages, examples:  https://www.armbian.com/banana-pi-m2-plus/ https://www.armbian.com/rpi4b/ https://www.armbian.com/odroid-hc4/
- download list is now completely automated, pulling from build config files https://github.com/armbian/build/blob/master/config/targets.conf
- added option to advertise recommended targets at download pages https://armbian.atlassian.net/browse/AR-1057 by setting a property in a targets.conf
- label supported / not supported for kernel is no more. instead label for CLI / Desktop / minimal
- added "Closed bootloader" property
- improved FAQ
- enabled WIP builds for: RPi4, UEFI arm & x86
Reminder! The release meeting is happening this saturday 14:00 UTC+1 (which is 13:00 UTC or 8 am EST or 2 pm CET or 5 am PST (sorry california dudes) or 9 pm CST).
I will look through the Jira issues remaining today. Would be great if you could check them too and add the ones you have finished (or are planning to include in 22.02) to the release.
@Igor @Werner @TonyMac32 @martinayotte @piter75 @ning @Myy @balbes150 @sfx2000 @ebin-dev @chwe @gprovost @aprayoga @lanefu @5kft @JMCC @going @jeanrhum @dolphs @jock @belfastraven @TRS-80 @Bozza @Rich Neese @sgjava @Mangix @tony013 @rpardini @yang @adeepn
12 hours ago, lanefu said:
anymore thoughts about group mention plugin for forum?
https://armbian.atlassian.net/browse/AR-1078 (one more is also interesting)
Added, but it doesn't work properly. I have tried by enabling it for all, but now it's enabled that administrators can call administrators. Dunno why its not working - support topic: https://invisioncommunity.com/forums/topic/439130-group-mention
Is there any available log from the meeting? Sorry for not attending, Saturday afternoons are busy for me sometimes.
19 minutes ago, Igor said:
here we need a list of all board maintainers
From Forum Name Cross Reference section of (new) Board Maintainers page in our documentation (and then a little multiple-cursors action in Emacs), et voila:  :D
@antondeveloper, @balbes150, @catalinii, @Heisath, @Igor, @yang, @joekhoobyar, @krachlatte, @LucasM, @piter75, @NicoD, @RadxaYuntian, @seclorum, @teknoid, @TonyMac32, @TRS-80, @ZazaBr
Hmm, although simply pasting a list of @user1, @user2, etc. did not activate the mention.  Had to go through manually and still start to type and then click on them.  :/
Edited by TRS-80
edit list of @user1, @user2 into actual mentions
@group_board_maintainers (which we need to establish :P)
New propery "Compatible" added to the board download pages. Currently used for Rpi and @joekhoobyar Odroid XU4 where I have added HC1, HC2, ... and removed separate page for those.
I want to suggest making a change to getting the source code for the kernel. Switch from using BRANCH to TAG. This will allow you to fix the source code used and synchronize it with patches, configuration and other settings. Now, at any start of the build, the source code is automatically synchronized and it is constantly updated to the latest available version, which causes a number of problems (destruction of some patches used, appearance \ removal of options in the kernel, driver changes). When using TAG, we can control switching (transition) to a new version of the kernel, i.e. this process becomes fully controlled and the version change is performed manually by the maintainers in their configuration files. But there is a drawback, you need to change the process of deleting the no longer used version of the kernel source code, there are different solutions that can be discussed.
https://github.com/150balbes/build/blob/armbian-tv/config/sources/families/media.conf#L67
1 hour ago, Heisath said:
Is anyone still working on something important, that should go into this release / RC ?
Outside bug fixing - rockchip64 current still needs to be bumped to 5.15.y
09.02.2022 в 15:31, balbes150 сказал:
The solution has been present for a long time. See how it happens for sunxi:
https://github.com/armbian/build/blob/3c1dde938cbea0bf0fee17049ad61cda74f1ee17/config/sources/families/include/sunxi64_common.inc#L78
https://github.com/armbian/build/blob/3c1dde938cbea0bf0fee17049ad61cda74f1ee17/lib/general.sh#L294
The function creates a shallow clone of the original linux-stable target branch. And can add a branch from another repository of the same version, but with additional commits. Switching is very simple. The function is tested and works for sunxi. If you set the key KERNELSWITCHOBJ=v5.15.7, it will extract this tag, but it will continue to update. Everything happens without changing the directory. The directory is always named as version 5.15.
I already have a solution for a full replacement for the fetch_from_repo function, but it has not yet been fully tested.
